Routing of Car Play Cable
We will be using Apple Car Play in our new 2020 RX350. It requires an Apple cable between the iPhone and the USB connector in the middle console. This means there will always be a cable running from the console to the iPhone. I'm thinking there has to be a way to route a cable from the console up to the phone holder area in a concealed fashion. This would be much cleaner and out of the way. I was just wondering if anyone else has done this or perhaps has ideas about how to do it.
Bill
Bill
Bill
Bill
I realize that Lexus made the data route so that your phone is "away" but honestly it is just easier to use if it is in the vertical holder (not while driving). I often forget to remove my phone from center storage and have to run back to car to get. With CarPlay I don't need to use my phone (btw it works perfectly for me....very happy with the integration and ease of use for what I do). As far as how to route what you are talking about, you could take the long way to the lower driver side door sill and then under front dash (I did a dash cam and found most of the panels very easy to remove and replace), or the direct route under the center. I do not believe that there is any channel from center storage area to run aux wire, so some minor surgery may be necessary. Good luck and let us know what you find/do.
I hadn't thought of routing the wire under the seat to the door edge and up, I'll look at that.
Meanwhile I wondering if bluetooth might be the way to go, what's your thoughts:
https://carplay2air.com/products/cpl...UaAsMlEALw_wcB
Might as well go for the wireless CarPlay accessory as any wires will be an issue. My seemingly brilliant idea for a wireless/always on setup was always having my old Android phone plugged in for Android Auto which is better than CarPlay in my opinion. I had an extra SIM with a free data plan but my backup option was to just have my iPhone automatically tether it. The only flaw to this plan was that I couldn't call/receive calls as it used the phone with data only...
