Can i use wheel offset 35 or 45 instead of offset 30
Can i use wheel offset 35 or 45 instead of offset 30?
My lexus rx350 is made in 2019. The original wheel offset is 30, so can i use some wheel offset 35 or 45 instead of offset 30
I'd be going for a 20mm offset.......I'm running TSW's w/ a 20mm, so the wheels are wider & the wheels are flush w/ the body.....Gets you to a wider tire as well........A 265-50x18 tire works great
EricTian (12-14-20)
thank u very much. But my lexus rx350 wheels is 20 inch and the tires is 235 55/r20 .
20mm offset.....
If you want to run your oem size tire, then sounds like your looking to get a set of 20'' wheels......To use those 235's , a great wheel is to go w/ TSW Ascent's in a 8.5''x 20''.....w/ a 20mm offset. That way you can run the 235's & later on you can upgrade the tire size to a 255-55 or a 255-50.......a 8.5'' width wheel is the max you can go w/ the 235's.....Hitup Discount & you'll have to order them.....It took me 4 weeks or so for them to get my wheels...I went w/ the Ascent's, as I was looking for a easy to clean wheel & for a clean looking wheel also....
genji
CT 200h Model (2011-2017)
10-14-17 02:46 PM
