2017 RX Clock Assembly Rattle
I had rattles coming from dash. Went to dealer last month and they pinpointed the problem. The clock assembly was replaced and the car was quite for 2 weeks.
This week the rattle is coming back, if I push the clock and the rattle is completely gone. However there is no rattle at all when the car is cold and the rattle only comes up after I drive for a while.
The dealer now refuses to fix it as they are not able to hear the rattle when the car is cold.
Any suggestions or anything I can fix myself?
Interesting! I'm having a similar rattle or buzz type noise on my 2017 RX450h that I have yet to pinpoint. I will check the clock also now after reading this, but it too only happens after warming up. Some days it's gone completely. Is this a fairly quiet type buzz rattle that you here at low RMP like taking off from a stop or rough / course roads?
However they didn't check immediately and thus no rattle at all...
The dealer told me they scheduled me for FTS don't know if that will be helpful..
And the rattle only happens when I drive the car for a while. If I tap the dash when the car is cold, it's quite. After the car is warm up and I tap the dash, I can hear the rattle
I would suppose the entire dash needs opened up to get to the back of the clock, where you could use tape or felt or epoxy or something to stop the movement that causes the rattle. There's a youtube video that shows the dash disassembly for a Gen 4 RX 450H. It's a non-trivial procedure, but not beyond an owner who has done such interior work before. You can see why the dealer would rather skip it if they can't get reimbursed under warranty.
Well in my case, this similar situation is not the clock. I've only had the car a few weeks and haven't been able to ride on the passenger side where it sounds to me like it;s coming from....BUT. This thread put me on track to the heater and warming up being the focus. I think it may be that little door window vent warming up and rattling. There is a rubber boot on the door that I've plugged with foam and plan to test that later today.
Why fix this yourself? You know it's the clock or vent on the side of it and likely how it attaches needs to be insulates with foam or a dampener of some type. Record the noise on your phone, take it in warm and insist that it gets fixed. You are under warranty, and they'll have to fix it if you prove it's there to them. That is my plan after I try to pinpoint the exact issue or area myself unless it's something easy like I'm trying now.
I have been to different dealer for like 10 time, the rattle comes back after 1 to 2 weeks. not sure what exactly is going on here.
Kam7001
02-06-21 03:51 AM
