Battery Replacement - DIY or Dealer?
Old 01-02-22 | 12:19 PM
  #151
Cocal's Avatar
Cocal
Originally Posted by exonw
My Canadian dealer replacement charge is CA$230 (battery+labor+ss+tax). Lexus Premium 84 though not sure of the part number.
I think that's a fair charge!
Old 01-02-22 | 12:20 PM
  #152
BensonTT's Avatar
BensonTT
Should have went with a Costco AGM battery
Old 01-02-22 | 12:33 PM
  #153
Cocal's Avatar
Cocal
I've had that very same battery on my 2017 and still going as strong as ever! I desulfate & charge it twice a year.
Now if I had a stop n go motor I'd definitely use AGM, Lexus/Toyota are good batteries and if I had my Druthers I'd chose Odyssey or NorthStar, but those are between$300 & $400 before installation costs,
monju0525 (06-12-24)
Old 01-02-22 | 01:18 PM
  #154
mikemu30's Avatar
mikemu30
I had mine changed yesterday at a local independent for $189. Three year free replacement. We'll probably trade it before the three year mark at this point.
Old 01-30-22 | 06:56 AM
  #155
cec327's Avatar
cec327
Default battery reset
2016 rx 350 does the car computer have to be reset after changing the battery?
Old 01-30-22 | 07:45 AM
  #156
Quantum501's Avatar
Quantum501
Scroll up....several posts regarding reset and saver.
A video from Viktor shows that reset not necessary if you do the job quickly...ie...have everything ready for a quick disconnect and reconnect.
Old 02-01-22 | 11:48 AM
  #157
Mickknight's Avatar
Mickknight
Default East Penn Battery?
I need help on deciding on what battery I should go for.. AAA has East Penn Battery's that they will install for you for about 158.. And lexus is 190 with there $50 off coupon.. What batter is better and more reliable ??
Thanks in advance
Old 02-01-22 | 12:51 PM
  #158
jcg0324's Avatar
jcg0324
Thanks in advance
A friend of mine has used AAA batteries in his Camry and they seem to be very well built. The CCA (cold cranking amps) on a 4 year old battery was still at the stated rating. I would assume then that the CCA when new would have been higher than the rating. East Penn is one of three manufacturers of batteries in the US. The other two are Exide and Clarios. The Lexus battery will come from one of those three companies. The Lexus battery in my 2017 RX 350 was well below the stated CCA when it was 3-1/2 years old. It's a tough call to make since all three companies can put out high quality batteries or cheap ones depending on what the customer wants.
Old 02-01-22 | 01:23 PM
  #159
raylor4's Avatar
raylor4
Thanks in advance
I would go with AAA.
Old 02-01-22 | 02:51 PM
  #160
Cocal's Avatar
Cocal
Thanks in advance
East Penn are VERY good batteries, if you go with AAA make sure that they do not disconnect for more than 10-15 min or you'll have to redo all the settings
Old 02-02-22 | 10:55 AM
  #161
mikemu30's Avatar
mikemu30
Interesting I had logged onto AAA to have them replace ours and it came back NO MATCH for 2017 Lexus RX. I had an independent replace it as I mentioned earlier in this thread.
Old 02-02-22 | 11:48 AM
  #162
coolbrazz's Avatar
coolbrazz
I've used AAA batteries in most of my cars for yrs, and had them to install them. They normally lasted 5-6yrs with no issues. Never had to replace my RX battery yet, and have no issue in having one installed with my supervision of course.
Old 02-04-22 | 10:12 AM
  #163
rc16's Avatar
rc16
10th Gear
Originally Posted by ViktorG
Hi guys, I am a Lexus Master Tech and I am working on a series of maintenance and repair videos that will cover the latest generation RX350.
Here is my video on how to replace the vehicle battery.
Please hit me up with any ideas/suggestions on what other stuff you would like to see in the future.
Thanks!
ViktorG
Thank you very much for posting those videos. They are really helpful!
Would it be possible, in the future, to post a video on how to retorque
nuts and bolts of drive shaft (AWD), giving us also the torque numbers?
Old 02-05-22 | 06:16 AM
  #164
cec327's Avatar
cec327
Default replacing battery
\\Thank you for your response. According to Viktor nothing needs to be reset. I found his answer to a question that was asked by a viewer of his video. Interesting, he did not mention a time frame. I will do it myself.
Old 02-05-22 | 06:29 PM
  #165
Lexspeed's Avatar
Lexspeed
Since 1968 I've always performed DIY battery replacement in the vehicles. I think I can do a better job and I like the labor charge (zero).
jcg0324 (02-05-22)
