Spark plugs change on 4th gen RX?
#61
I hear you. I never have and never will keep a car to 150k let alone 300k miles. But I certainly do the right thing maintenance wise regardless. 60k plugs just seems like overkill to me. The last car I actually had plugs changed on was an 01 Grand Prix at roughly 100k and those were probably platinum. Noticed zero difference after the change. Thanks for your input though!
#62
#63
Seems very strange that Lexus on the RX would go from changing the plugs in a 2015 from 110,000 miles to 60,000 miles in a 2017 just in order to adhere to the emissions warranty. members that had theirs changed at 110,000 miles stated they looked new. I will pass since it is a over $500.
- Spark plugs are specifically mentioned in the Lexus warranty guide as being a maintenance item (no warranty coverage) EXCEPT:
- Spark plugs are " Warranted until first required maintenance under terms of the California Emission Control Warranty." This language is confusing, since spark plugs are referenced with a 60K change interval. It is not clear what "first required maintenance" means in this context. The Lexus documentation is vague. I don't know if that is intentional or the result of lousy writing.
- It appears that spark plugs are NOT warranted as part of the Federal Emission Control Warranty, as the Lexus guide includes spark plugs in the 'what is not covered' discussion of the Federal Emission Control Warranty
My state of WV has not adopted the CA standards and does not have any emissions testing. (We do have an annual vehicle safety inspection....) No way will I change the plugs at 60K miles. I might consider doing it at 120K.
mikemu30 (07-02-21)
coolbrazz (07-03-21)
#67
Aren’t the crush washers on spark plugs supposed to be one-time use? So by loosening them and then re-torquing them, there is an increased likelihood of the plug leaking and possibly damaging the threads in the head.
I’ve changed a lot of spark plugs over the years and never had one so seized that a half inch breaker bar couldn’t budge.
#69
#70
Pretty bizarre- well done Lexus offering clarity on this one😋. I'll roll the dice and hold off on spark plugs for a bit. My wife's RX currently at 56k and still runs as silky smooth as day one.
#71
Spark Plug Change How To Video
Many of you guys follow Car Care Nut and he finally did a video for the spark plugs on our engine.
This guy has a ton of no nonsense videos for Toyota Lexus and tells it like it is regarding what the manual/dealer says to do vs a real tech and owner does.
Good news is that the rear plugs are relatively easy to get at compared to previous generations. He also gives some "shortcuts" and hints vs the TIS manual to make it even easier.
The following 6 users liked this post by Quantum501:
396chevy (01-08-22),
Gdhillon (03-12-24),
ghost31711 (07-22-21),
jollick (07-22-21),
Lexspeed (05-17-22),
and 1 others liked this post.
#72
Go to the manual in the glove box and find the intervals, it's clearly listed in there. I confirmed what the manual said a shop with Mitchell1 Repair manual.
#75
Here are my plugs at 82k. They were pretty easy to do with The Car Care Nut’s video. There are slight variations with the RX but pretty easy to figure out.
Six plugs at 82k
Surge tank
Six plugs at 82k
Surge tank
The following 3 users liked this post by kalvink:
