Changing out turn signal bulbs to LED
These are the bulbs I ended up getting for the front and rear turn signals.
And these are the ones I got for the reverse lights.
All of the bulbs are much brighter than stock and no hyperflash.
Installation took about 15 minutes for all of the bulbs. You do have to remove the rear side taillights in order to change the rear turn signal bulb. There is a little plastic cover that you pop off and then you have access to the two 10mm bolts that hold on each taillight.
https://www.amazon.com/LASFIT-Resist...omotive&sr=1-4
https://www.amazon.com/LASFIT-Resist...omotive&sr=1-7
https://www.amazon.com/dp/B081YJ7G81...roduct_details
1. What is the difference between the links that you sent for the front and rear turn signals? Are they different connectors?
2. Do the bulbs get noticeably hot when in use? I would assume not since they're rarely ever used unless hazards are on or at a long left/right turn stop
3. Similar to question 2, do the bulbs start hyperflashing after a period of time?
4. What's the installation like for the front lamps? Any tips on what to avoid or spots that are hard to reach?
5. Any pictures/videos you can show us of it working?
Thanks so much again for pioneering this quest for us! lol
Last edited by Saranhai; 07-19-21 at 03:02 PM. Reason: Added another question/request
Theres a black piece that you have to pop out and there's 2 screws behind that black piece you have to remove. Once the screws are out, the tail light will pop out rearwards. I found the instructions on the manual. Page 620 on the 2017 manual.
side note, I know about it Cuz I also changed my turn signals to led. I bought the Luyed LED bulbs from amazon. They've only been in the car for a couple of days. I'm giving it a week before I post a thread about my review on it. So far so good though. I did both the front and rears. It has built in resistors so the turn signals won't hyper flash.
here's the link.. LUYED 2 X 2590 Lumens Extremely Bright Error Free 3030 Chipsets 7440 7441 LED Bulbs Used for Turn Signal Lights,Amber Yellow(Brightest Amber LED On the Market) https://www.amazon.com/dp/B01LWSFFF5..._dcIVybWC0YT23
VonSchmill
GX - 1st Gen (2003-2009)
03-16-20 08:04 AM
