Ignition switch
Old 04-01-21, 09:33 PM
WIZARD1325
WIZARD1325's Avatar
Default Ignition switch
So I am in love with the new switch on the newer Lexus RX 350 2021s.
i did some research on my car and i notice that it has the exact same pins and the trim is exactly the same yet online it states that it will not fit my vehicle...so im a little confused..
do you think it will work? I dont like my push start button because it doesnt even light up booo.. posted pics for comparision old to knew.
Has anybody changed theirs yet?
Old 04-02-21, 05:00 PM
WIZARD1325
WIZARD1325's Avatar
Ok so this is what i can confirm for a fact.
1. first photo is from a 2021 RX 350 (dont ask how i got this photo =0)
2. second and third photo are the exact same wires from a 2016 RX 350 and a 2021 RX 350 (identical plugs and wires)
3. Last photo is my ignition switch from 2016 RX 350
So what are the chances the 2021 will work?
Old 04-02-21, 05:03 PM
WIZARD1325
WIZARD1325's Avatar
LEFT 2021 RX 350 to the right 2016 RX350
Old 04-02-21, 05:05 PM
WIZARD1325
WIZARD1325's Avatar
This numbers look all identical it just has to work! what do you guys think?
Old 04-03-21, 03:42 AM
Quantum501
Quantum501's Avatar
I noticed that since the newest model's parts are sometimes not in the database, that I get "parts won't fit message". This happened with several parts when I first picked up my 2020.
I have no idea for sure but would assume that no change took place with 2021 on this part.
Old 04-03-21, 04:48 AM
JSracer
JSracer's Avatar
if they are both in your hand and your determined, plug it in and see what happens. what's the worst that can happen, right ??
Badhobz (04-03-21)
Old 04-03-21, 07:24 AM
mikemu30
mikemu30's Avatar
Received 2,542 Likes on 1,815 Posts
What on earth is different🤔🤔
Old 04-03-21, 07:38 AM
Badhobz
Badhobz's Avatar
^some fake carbon fibre trim around the circle and the button looks to be convex instead of concave.
Old 04-03-21, 08:07 AM
eddie420
eddie420's Avatar
Yes, it should work. Takes 2 minutes to make the swap.
Old 04-03-21, 08:10 AM
WIZARD1325
WIZARD1325's Avatar
Might pull the trigger in it
Old 04-03-21, 08:12 AM
WIZARD1325
WIZARD1325's Avatar
I pulled it out of another vehicle and took photos. I couldnt do a swap due to i didnt have my vehicle.
Old 04-20-21, 08:06 AM
WIZARD1325
WIZARD1325's Avatar
Default 2016 RX 350 start stop upgrade
I upgraded my stop start button on my 16 rx350 with a 2021. Everywhere online said it didnt fit or work. Dealerships told me it wouldnt work. I didnt believe them
I took the pluge to test my theory out amd here are the results
https://youtu.be/yCy2DtPRKQE
The following 4 users liked this post by WIZARD1325:
Aeon (04-20-21), Badhobz (04-20-21), bamalam (04-20-21), raylor4 (04-20-21)
Old 04-20-21, 08:18 AM
Badhobz
Badhobz's Avatar
cool, i didnt know you can just pull the leather side pieces off like that. that's good to know when I eventually take it all apart to add extra foam to prevent rattles / vibration noises from that center console
WIZARD1325 (04-20-21)
Old 04-20-21, 01:56 PM
TechNut
TechNut's Avatar
Nice video! You did a good job documenting the process with this video. Not to diminish from your effort, but I’m struck by how everything is just plastic clips holding it all together. Is there any wonder modern vehicles develop squeaks and rattles as they age, or as temperatures change. I imagine most brands are done this way so it isn’t a criticism of any particular carmaker, just an observation after seeing how easy it was to dismantle the dash.
Old 04-20-21, 06:28 PM
bamalam
bamalam's Avatar
Looks good and nice work. I don't remember if you ended up with an F-sport or not, but notice you have the sport pedals. If those aren't original, where did you get them?
Quick Reply: Ignition switch
