OBDII Scanner say Rain Sensor Code P1014
Hi,
I noticed my local dealer fixed the AC problem in my RX but using the Bluedriver OBDII scanner, I noticed this error code:
1 Rain Sensor Code
P1014 LT Connection (GND Short)
The dealer cleared the code and I drove the vehicle a number of miles and it came back.
Did anyone else see this issue? What's the fix if so.
I talked to one Service Advisor and he couldn't find it online for the error code.
Thanks.
1 Rain Sensor Code
Thanks.
https://rennlist.com/forums/attachme...bdii-codes.pdf
I did a web search and can't find it for Lexus. Maybe the BlueDriver misdiagnose?
I emailed Bluedriver.
I check the oil and it's not 5K miles from last oil change yet.
Here's their response. Not sure what it is really saying. Dirty oil or oil pressure measurement issue?
I guess I'll email them back.
If the BlueDriver is reporting it then so would your vehicles ECU as we only display the information given by the vehicle.
I did find this description and possible causes online for this code.
P1014: Exhaust camshaft position (CMP) actuator, bank 2-incorrect park position
Possible Causes: Engine oil level/pressure, mechanical fault
Hi,
1 Rain Sensor Code
Thanks.
1 Rain Sensor Code
Thanks.
