Brake Torque Specs
The front and rear mounting bolt torque spec is 25 ft lb. This is from TIS for 2016 - 2020 RX.
6th Gear
To be honest, I have never torqued my brakes....just got them "snug". Ironically I torque most of my other specs, esp those with crush washers to be sure that they compress, but never on brakes....and never had an issue.
6th Gear
The only specs I could find in the TIS was the 25 ft lbs.
77 ft lbs seems to be a realistic number on similar platforms from what I can find so far.
Can someone please tell me what the proper torque specs are for tightening the electric parking brake motor to the rear caliper on a 2020 RX350? Try as I might, cannot find this anywhere.
Thank you very much for your help.
Per TIS "Using 5 mm hexagon socket wrench, install the parking brake actuator assembly to the rear disc brake cylinder assembly with the 2 bolts and torque to 8.4 Nm"in
Yes! Thank you so much! That is exactly what I was looking for.
Quantum501 (10-29-23)
bigchicken
LX - 3rd Gen (2008-2021)
12-08-19 03:37 PM
RA051823
05-29-17 03:40 PM
