Power Back Door Issues
Old 04-04-22 | 05:30 AM
Lexspeed's Avatar
Lexspeed
Originally Posted by msnow
Yes, I prefer the precision of your manual method too and it seems to work on my 2022.
Confirmed this method with my 2022. So simple to adjust height of door....even a caveman could do it.
msnow (04-04-22)
Old 04-06-22 | 12:34 PM
zep4ever's Avatar
zep4ever
I'll guarantee it's weak gas struts.
The lift motor can't lift the weight of the door so the struts do most of the lifting and also keep it up there once it's up.
Old 04-06-22 | 01:02 PM
ravenuer's Avatar
ravenuer
Good point. Worth a shot.
Old 12-28-22 | 09:30 AM
relm2's Avatar
relm2
2nd gear
Default 2016 RX 450H rear hatch stops opening halfway
Hello all,
My 2016 RX 450H rear hatch stops opening halfway. Looks like a problem with the struts but Lexus is quoting me over $1,300 to fix it! Looking online, I find the parts for around $80 but wondering if I can go to a non-Lexus repair shop or any other suggestions to what I'm sure is a very common problem? How can this possibly be $1,300 for the struts?
Old 12-28-22 | 10:57 AM
ravenuer's Avatar
ravenuer
Originally Posted by relm2
Hello all,
I see no reason you couldn't go to any shop to have the struts replaced. It shouldn't be a difficult job.
Old 12-28-22 | 01:19 PM
relm2's Avatar
relm2
2nd gear
Hello all,
EDIT: first, thanks to the admin for moving my post to the proper thread. I feel stupid for posting this but after reviewing the thread and seeing there was a setting that impacted the default height of the rear hatch, I checked that in my car and saw it was set at 3. Now that it's 5, it is working correctly. So, no service needed! Whew. I had a 20k check last week and while driving there was a momentary power restart which I never had before but it seemed to reboot to default and that must have included the hatch height. Thanks everyone.
The following 2 users liked this post by relm2:
jollick (12-28-22), ravenuer (12-29-22)
Old 04-10-23 | 05:50 AM
shunt's Avatar
shunt
1st Gear
Default Liftgate Actuator Settings Memory
Anyone ever have issues with the liftgate settings not staying programmed? I’ve reset mine countless times and it still doesn’t open correctly. I press the button on the gate and it goes up 6” to 1’ beeps and stops. I press again, down, then again up a bit higher, and on and on until it’s all the way up. It’s maddening.
Old 04-10-23 | 06:29 AM
kmiller882's Avatar
kmiller882
Is this how your doing it?
If that is how you are doing it and it is still not holding, you may need to take it to your dealer. I've had no issues setting mine at all and it has never "reverted".
shunt (04-10-23)
Old 04-10-23 | 07:16 AM
ravenuer's Avatar
ravenuer
What year? Still under warranty? Dealer.
Old 04-10-23 | 08:39 AM
Nail34's Avatar
Nail34
Physically push the rear hatch all the way to the top, that will clear all settings. Then try to set it again. Hope that works.
shunt (04-10-23)
Heids82
11-01-21 06:26 PM
bullcity
10-18-21 06:53 PM
andye39s
RX - 4th Gen (2016-2022)
11-05-19 04:39 AM
Ex-Lexic
Hybrid Technology
05-21-10 07:26 AM
toppower
11-29-07 09:02 PM
Quick Reply: Power Back Door Issues
