2018 rx350 oil leak????
Old 04-22-22 | 03:41 PM
dubzino's Avatar
dubzino
Default 2018 rx350 oil leak????
Long time member but strayed away from lexus for a little while and now I'm back. So we had purchased this 2018 rx350 about a few months ago. And now I notice there is a oil under a part of the car. Is this the transmission? Or the differential? I am so nervous. I came back k to Lexus because of the amazing reliability I had with my old gs350. Several mercedes and bmws later. Here I am again. I tried to take as good pictures as I could. Has anyone seen this before?
Old 04-23-22 | 05:52 AM
autotech13's Avatar
autotech13
That looks like a leak from the transfer case. Have your dealer check it out before you run out of fluid.
Old 04-23-22 | 10:59 AM
dubzino's Avatar
dubzino
Default Lexus rx350
Going to do that this week. Thanks. What are the intervals for that fluid? As well and transmission and differential?
Old 04-23-22 | 11:07 AM
Quantum501's Avatar
Quantum501
I did the Rear Diff and Transfer case at 30k, and will do drain and fill 1x on Transmission at 50k. Check out Car Care Nut on YouTube. He is a tech and these are his recommendations vs service manual (never believe in Lifetime ATF) Those numbers are in miles....I see that you are in Canada.
Old 04-23-22 | 12:56 PM
Cocal's Avatar
Cocal
Best thing to do is every 40-50Km the 1st change is the most important as it contains most of the impurities, for the ATF same schedule, but if you have more than
80K Km on it Drop & Fill (several) may be a more prudent approach.
ravenuer (04-23-22)
Old 04-23-22 | 07:36 PM
dubzino's Avatar
dubzino
Sounds good guys. Thanks for the prompt replies. I looked at the videos. Gonna service all 3 this week. I'm at 69km
Old 04-24-22 | 06:22 PM
mikemu30's Avatar
mikemu30
Transfer case leak sb covered by the power train warranty. Six years 70k miles.
coolbrazz (04-25-22)
Old 04-26-22 | 10:12 AM
dubzino's Avatar
dubzino
what does "sb" mean. Andnhownthebheck is the lexus transfer case leaking at this low mileage.
Old 04-26-22 | 11:23 AM
Cocal's Avatar
Cocal
It shouldn't leak, but since you bought it 2nd hand, what do you know of the previous owner's problems/maintenance if any?
It's hard to reverse solving problems of a previous owner unless resolved by a Lexus dealer and on record in their computer.
Old 04-26-22 | 01:07 PM
huskies's Avatar
huskies
10th Gear
sb = Should be.
Old 04-26-22 | 04:24 PM
dubzino's Avatar
dubzino
I took to a local lexus mechanic today and he says he thinks it's rear main seal. How could that be so early. I have appointment with lexus next week.
Old 04-26-22 | 05:20 PM
ravenuer's Avatar
ravenuer
A rear main in a 2018? Doesn't seem likely to me.
Old 04-26-22 | 06:40 PM
frankymenz's Avatar
frankymenz
Car care nut was discussing rear main leaks on the 3.5 V6 motors and says sometimes it’s actually the retainer/housing which the seal is pressed into and bolts to the rear of the engine, I think it’s got FIPG for sealant between it and the blocks rear face.
Old 04-27-22 | 06:59 AM
mikemu30's Avatar
mikemu30
Originally Posted by huskies
sb = Should be.
Thank you
Old 04-28-22 | 08:16 AM
E46CT's Avatar
E46CT
^young 20 somethings these days with their acronyms. smh.
Mewannalex (09-28-23)
Quick Reply: 2018 rx350 oil leak????
