Help! Sound system way too loud.
My new 2022 RX was delivered with all of the radio and SXM channels set a maximum volume. Is there a universal setting that I can change so I don't blow out my eardrums? And could the Automatic Sound Levelizer be the culprit?
As I was driving home from the dealership, I flipped on the radio and nearly jumped out of the vehicle because of the volume. It was painfully loud.
If there are no suggestions, then I am putting on ear protection to flip through each channel and manually set the volume to a normal level.
Thanks in advance for your responses.
The following 3 users liked this post by jcg0324:
Thanks for the suggestion, but I did turn down the volume. When I skipped to the next channel it was at max volume too. I was wondering if there was a global setting that worked across all channels so I would not have to blow out my eardrums 36 times.
If nothing else, call or visit your dealer. They usually go over most of the common instructions upon delivery.
ravenuer (06-01-22)
