Coolant Replacement FKS
Old 05-29-22 | 07:50 AM
Quantum501's Avatar
Quantum501
Default Coolant Replacement FKS
Wondering if anyone has done the coolant change on the 2GR - FKS.
Car Care Nut did a video on the old engine and said that the newer FKS is much more difficult....I assume that the bleeder is gone or more difficult to access.
Could not find a thread here or any videos on YouTube.
Old 05-29-22 | 11:38 AM
dibl's Avatar
dibl
The official Toyota procedure exists, not that it is a simple one:
https://www.ttguide.net/coolant-712.html
Quantum501 (05-29-22)
Old 05-29-22 | 11:39 AM
chuyrobles's Avatar
chuyrobles
According to Gen3 Tacoma owners (Taco 2016-present has same engine), there is no bleeder valve. Also, schematics show a drain valve for each cylinder bank but they have only found the one on the passenger side.
Also found a youtube video for 2019 Camry fluid service, but done on a hybrid; the mechanic mentions non-hybrid models.
https://www.tacomaworld.com/threads/...oolant.624165/
Old 05-29-22 | 02:15 PM
dibl's Avatar
dibl
The diagram shows a significantly different radiator from the Gen 4 RX. However, I assume the basic procedure and list of things to drain is still correct for an RX.
Old 05-29-22 | 02:23 PM
Quantum501's Avatar
Quantum501
Thanks for the post. Don't need to do this right away, so I have some time. Someone will eventually post a video....maybe me if the time comes.
On my old Acura it was drain and fill with no spill funnel kit. I will poke around a bit more to find more info. Forgot to look on forums of other vehicles with same engine.
Old 05-31-22 | 05:47 AM
kalvink's Avatar
kalvink
I've done just a drain a fill of the radiator at around 100k miles. Coolant looked pretty good, so didn't drain the block. It's pretty straightforward to drain the radiator and the no-spill funnel kit was good but the way the radiator cap is situated can make it tip over, so keep an eye on it.
The following 3 users liked this post by kalvink:
bamalam (05-31-22), dibl (05-31-22), Quantum501 (05-31-22)
Old 05-31-22 | 01:26 PM
dibl's Avatar
dibl
Here's an interesting item -- apparently the Toyota Avalon also uses the 2GR FKS engine. Upon searching for the coolant drain procedure for that model, I found this site:
https://www.tavalon.net/138/2gr_fks_coolant.html
Here's the interesting part -- this diagram shows the engine block drain plug in a different (and much more logical) location than the Tacoma diagram (which appears to show it on left cylinder head!).
Old 06-01-22 | 01:13 PM
Quantum501's Avatar
Quantum501
Yeah, although the engine is the same, it seems that the procedure for the RX is more complex for the full coolant replacement. When I did my TIS 2 day subscription, I forgot to grab the coolant procedure. I may pop back on when the time to replace get near. I asked Viktor to add this to his list of video projects when he can find the time.
Old 06-20-22 | 03:24 PM
Mcfancy14's Avatar
Mcfancy14
2nd gear
Default Bleed burp radiator
Planning to change coolant and does anyone know the location of the bleeder valve or is this model self burping?
Old 06-20-22 | 04:05 PM
Quantum501's Avatar
Quantum501
I asked this the other day in some thread with no information. Apparently the bleeder has moved to an inconvenient location. I think that the Car Care Nut posted a video and mentioned that the latest version of our engine makes a full coolant bleed more difficult.
I put out a request to Viktor to do a video on the topic and he said that he will add it to his list.....his videos are great, but I am sure that he is a busy guy.
I might at some point log into TIS with a 2 day subscription to download a few files that I neglected to grab when I first purchased by vehicle in 2020.
If you find out any information, please post and let us know.
Old 06-20-22 | 04:09 PM
Quantum501's Avatar
Quantum501
https://www.clublexus.com/forums/rx-...ement-fks.html
I knew that there was a post....just forgot that I was the one who started it.
Old 06-21-22 | 01:55 PM
Mcfancy14's Avatar
Mcfancy14
2nd gear
Thanks for all the info….is there a consensus on whether a bleeder valve exists?
Old 06-21-22 | 02:10 PM
Quantum501's Avatar
Quantum501
not that I could find. I think that there is, just not sure where. No one else has confirmed for this engine in OUR VEHICLE.
As I said, the 2 day subscription to TIS is in my opinion worth the price since you can download almost every common service file with procedures, parts, specs, etc. I can not promise that the full coolant procedure is in there, but I can't image why it would not be.
Old 09-03-22 | 02:29 PM
Quantum501's Avatar
Quantum501
Turns out that I have the TIS document for the procedure.
It appears that there is a Cylinder Block Drain **** Plug on the driver side of the engine in a similar position as posted in the link from dibl in post 2.
I have not looked but I am guessing that the location is a pain to reach.
The procedure requires several squeezes of the number 1 and number 2 hoses.
As mentioned previously The Car Care Nut does this on the old version of the RX engine and then mentions that it is not as easy on the FKS.
I still have some time and hope to find a specific video for our vehicle.
Old 09-04-22 | 08:13 PM
GS4_Fiend's Avatar
GS4_Fiend
Keep us posted if you are planning to do yours.
Drain and refill and bleed IMO is already good enough. No need to remove the block drain.
Quick Reply: Coolant Replacement FKS
