Adaptive throttle/transmission question
Does anyone know if there is a separate learn/adaptive for each drive mode? When I was in at the dealer on Monday, I mentioned that the transmission/throttle response is all over the map. The tech asked if anyone else beside me, drives the vehicle. My hubby does. The tech said that would cause an issue with how the transmission behaves as it is constantly trying to adapt to different driving styles. Ok, makes sense but it is a real pain. So, my question is, if I drive it in sport mode and my hubby always drives it in Eco, is it smart enough to learn our different driving styles in the respective modes?
TIA
~N
TIA
~N
TIA
~N
TIA
~N
I believe that each mode has its own transmission mapping. In “eco,” the shifting is set for best fuel economy. In “normal,” the mapping is designed for a more normal throttle/transmission response, and in “sport,” the transmission is set to go-fast mode without regard to fuel economy.
Yes that's what the different modes are for but the OP is asking if each of those modes have their own learning capability, ie: put it in Normal mode, drive very hard and the car will learn to hold gears a little longer. Put it in Sports mode and say drive gently will the car hold the gears a little longer compared to how Sports mode is normally. The OP wants to know if after that learning will it remember the Normal mode and then put it in Sport mode will it remember that Sport mode learnt driving style.
I did a search, but didn’t find it, that we discussed this back in generation three and the RX did learn your driving habits and began to anticipate your actions. If you developed or had poor driving habits and wanted to improve them and start training the car all over, the car’s memory needed to be wiped clean for a fresh start.
Of course my memory maybe faulty and that discussion is only in my head!! Or a discussion with a service advisor back in 2010.
It should be by which key fob was detected to start the vehicle instead of the drive mode... So one setting per driver in whatever mode it is set to.
But yeah, that you be a great feature.
ellydogns (11-12-18)
I drive slow and I drive fast. I drive slow or fast in all 4 driving modes, eco used the least.
I drive in manual "every" time I drive, I leave my home and go down a hill in 1st gear and upshift into 2nd at about 9 mph and stay 2nd as I go up hill otherwise it quickly goes into 3rd and the car lugs and lugs and finally, begrudgingly, jumps into 2nd as I step on the gas pedal. If my math is correct, that's 16 different driving styles. Seriously, how does the transmission adapt to a driver who has a multiple personalty disorder??
My RX was a 18,000 km used vehicle and I had heaps of trouble with the tranny - obviously I didn't know how the previous owner drove, I also was changing fuel types (reg, premium) plus adjust my driving style to accommodate the poor changes I was getting, so again the tranny was getting confused. At my first service they reset the ECU for me and, magic, far, far better and over the weeks improved further. Now she drives very smoothly but still can be caught out in the wrong gear in busy situations - then I use Sports mode where she's cooooool.
GSF, My point is I don't want to drive the same way all the time just to keep my car happy. Sometimes I merge onto the freeway slowly and sometimes I floor it.
Do you consciously drive in the same manner so that your tranny won't get angry with you?? LOL I guess It would be easier for someone in a flat, rural area to have the same style, not so much in a metropolitan area. Most of the time my car drives quite well and then there's the OU OH moment, even in sport or sport+.
I wasn't having a go at you I was just saying how it operates and I don't think it's good the way it learns - they need a better system. I do drive the same mostly, in a rural town, so slow and gentle mostly, when I visit the big city (Sydney) I usually put it in Sports because it's the quick or the dead there. Even though I drive the same mostly there are times I wont to go faster and yes, the car responds poorly to it, that's when I put it in Sports.
GSFRX350 (11-13-18)
10-18-12 03:34 PM
itsmeegan
RX - 1st Gen (1999-2003)
03-24-10 02:32 PM
