Front Dash Cam Recommendations - Do You have One You Recommend?
#121
‘With the existing cameras on the new RX, Lexus could turn it into one heck of a security system but they don’t. All that hardware doing nothing.
jahnjva (09-06-23)
#122
For my new RX500h I went with the Viofo A119 Mini 2 (front camera only). I have been very happy with the video quality (2592 × 1944 @30fps) so far. I installed a 512G SD Card so I can get about 40 hours of recording time.
I didn't want to do anything evasive on the initial install so I just ran the wire around the mirror assembly and the windshield along the a pillar and connected it to the USB C port. The wire is only visible in the corner of the dashboard by the speaker but I don't really notice it anymore so I may just leave it this way instead of opening up the pillar.
#123
#124
Smart phone
Anyone here using this instead?
#125
Yes, this is the route I am going. I would have loved a front/rear setup hardwired, but it does not seem to be cheap or easy. I use SYGIC navigation with the dashcam option. It is nice since it is offline nav, too. https://www.sygic.com/what-is/dashcam Unfortunately, I do not know if there is a non-subscription mode anymore. I have a lifetime license that I've used in places where there are no cell phones.
tedward155 (09-24-23)
#126
I went with a dash cam from Aliexpress, looks similar to what FITCAMX sells. Came with a rain cable that you can plug directly into ACC sensor port and hardwire. I have it hardwired and it works very well. Front 4K cam is very clear but rear cam is bad but useable. Parking mode can record in timelapse mode and you can set the time intervals you want it to record for it. Doesn't have any settings where you can set the voltage cut off though. Connecting it to Wi-Fi is fast and app is easy to use. Paid around $100US
#127
I went with a dash cam from Aliexpress, looks similar to what FITCAMX sells. Came with a rain cable that you can plug directly into ACC sensor port and hardwire. I have it hardwired and it works very well. Front 4K cam is very clear but rear cam is bad but useable. Parking mode can record in timelapse mode and you can set the time intervals you want it to record for it. Doesn't have any settings where you can set the voltage cut off though. Connecting it to Wi-Fi is very easy and fast and app is easy to use. Paid around $100US
Tommyyg (09-28-23)
#128
#129
I searched a few dealership websites to see if any of the RX's had any dashcams from the factory. I remember I found a few before, but never paid attention. Harder to find pictures of the actual RX, instead of stock pics. Took a good bit of searching, but found one RX in Las Vegas with the dashcam installed on the right (passenger) side, it seems.
https://www.lexusoflasvegas.com/inve...amba3pc015316/
Dashcam
$375
Dashcam
$375
- The Integrated Lexus Dashcam is designed to reliably capture video images sound and location data while you operate your vehicle. It is designed to begin recording upon ignition to capture drive or on impact whether moving or while parked. Features include:Playback or video download is available via Smartphone App or PC toolOnce downloaded you can also share these videos on your social media channelsIncludes a 16GB Industrial Grade Micro SD memory card
I asked the same. Even printed the picture and showed the service rep. They have no answers. All I can think is the power cord is too short to get to the place where there is power, I don’t know. The rain sensor is on the right side of the rear view mirror so it will be way to the right of the driver. Why put the emergency button on it when it is so far away?
Sometime life does not seem fair, but in the scheme of things, this is only a small problem. Things can always be worst!
#130
I used the Toyota power adapter #PT949-48210 to tap into a wiring harness inside the rear view mirror housing to power a Blackvue dash cam. This part is a 10 pin connector and it plugs into the harness found on the LEFT (drivers) side of the mirror housing. I needed to modify the adapter by removing the existing camera power plug and replacing it with a barrel jack that the Blackvue uses. I routed the power wire out of the right side of the housing cover and mounted the camera centered just below the housing.
I see no reason why a camera cannot be mounted on the left side of the mirror housing, so why dealers claim that this isn't possible doesn't make any sense to me at all. I do have the digital rear view mirror if this makes a difference; I really don't know if it does or not.
#132
I have had mine for about 6 months and its working great. I have a 2nd industrial 16GB card I use when I want to see the recording. I find viewing on a PC is easier than the phone app. (less glitchy).
CCGS (10-13-23)
#133
I've been thinking about it. The only cons I've heard is that since it's only 1080p, you can barely read the license plates. How is that?
#135
The TX has the new Lexus dash cam 2.0 as an accessory, but the RX only has the 1.0 here in Canada.
The Lexus dash 2.0 can be a 2 channel (front and rear) but is very expensive and it looks like a BlackVue model.
L
L
CCGS (08-31-24)
