Rattles in new RX350H
When I had my 2021 ES, the sun visor cover seemed to rattle. Sliding it open seemed to fix the noise. i also massaged/somewhat bent the sunvisor back and both to slightly affect the fit of all the plastics. the noise seemed to go away by doing that. worth a shot
charles267 (12-05-23)
Thanks so much for the advice!
Goldmember
Oh my god... The hatch noise/creak is really bugging me and we haven't figured it out. Has anyone figured out what the noise from the back area is? It seems to only happen when going over uneven surfaces, like driveways for me.
As for the front noise, I only just started to noice this and it does sound like it's coming from the passenger side visor/sunglass area, so I'll check both of these areas. Thanks.
Dash rattle
UPDATE: Took it to the dealership yesterday as the sound had gotten worse (sounded like two empty plastic water bottles rubbing against each other). They confirmed noise right away. Said the head unit/navigation display (that sits between the seats on the dash) was rubbing against trim piece below it. They took out the head unit and put in felt which entirely resolved the problem, and I might also add I have the base trim with the smaller display. No noise anymore even on the roughest roads. The display and trim piece below it seem to fit tighter together after the repair when running my finger gently between the screen and lower trim compared with prior to the fix. Here's the repair order below:
Sunglasses for me ... the little space is not lined or covered with any protection so its in essence plastic against plastic. I used a sunglass bag to put my glasses in then into the cubby and the problem was solved.
Same for me for about six months (2023) until I turned the glasses upside down…no more rattles.
Our RX450h+ has a rattle coming from the roof cross brace over the rear seat. It sounded like it was coming from all over, depending on where one's head was held.
I do have another 2 slight rattles; it seems it's when I rest my elbow on the driver door, that sounds like it's coming from the back area; and another one on the other elbow on the top of the glove box. Only heard while driving in silence.
jack2018
RX - 4th Gen (2016-2022)
12
04-12-18 05:33 AM
