Winter tire options
Old 07-01-23, 02:44 PM
  #46
ggebhardt
ggebhardt's Avatar
I would love to see a Michelin Cross Climate 2 in 21” but I don’t see it.
Old 07-01-23, 08:11 PM
  #47
Eagleboy99
Eagleboy99's Avatar
Cross Climate 2 is available in 16"-22"
Old 07-02-23, 05:38 AM
  #48
budwom
budwom's Avatar
Interesting tire...we live in snow country and require a full snow tire, but this tire gets very positive reviews regarding snow traction, and it has a very snow tire-like tread pattern...reviews are generally very good, high marks for snow, somewhat more middling for wet conditions.
Could be a contender.
Old 07-02-23, 07:09 AM
  #49
Eagleboy99
Eagleboy99's Avatar
I will pretty much have to go with the Cross Climate (I have had great luck with Michelins over the years although our current Defender LTXes are meh.) since my fave Nokian WRG3/4 all-weather do not come in the right size. Even the Cross Climate will be slightly different, but very close to OEM.
We travel into the mountains to ski and in BC, winter tires are required on mountain passes, but the Cross Climate is acceptable. There are a couple of other all weather tires, but I've not checked them out yet for sizing. One would have thought there would be more options for Lexus, esp. in the now popular larger sizes up to 21".
Old 07-02-23, 07:13 AM
  #50
budwom
budwom's Avatar
I'll have a look at the Cross Climates but have historically liked the Nokian Hakkapelliitas...most "all weather" tires just aren't great in big snow, but I like the pattern on the Cross Climates, and the reviews are good.
Carbuff2 (07-02-23)
Old 07-02-23, 07:19 AM
  #51
Eagleboy99
Eagleboy99's Avatar
Yeah, Hakkas are the best by far. I would have them if we lived in a true mountain town like Revelstoke BC, but in much of the area, there are dry(ish) roads that lead to the ski areas and a studded winter Hakka would be overkill.
My personal experience with the WRG series has been excellent even in big snow in the mountains. As good a sa true snow tire? No, but then no second set of tires, no extra rims with TPMS, not changeovers. And if the weather is that bad, I'll just stay put and wait it out. There are worse things than getting stuck at a ski area on a powder day!
Old 07-02-23, 10:41 AM
  #52
ggebhardt
ggebhardt's Avatar
If there are 21" Cross Climate 2 that fit my 350h, that will be what I want. I think i looked and it did not come in the same size I have mounted. I put them on my F150 Platinum truck and they we awesome at Beach Mountain during ski season. They are quiet, had great handling and wore well. They are not cheap but worth the cost if you need them.
Old 07-02-23, 04:37 PM
  #53
Eagleboy99
Eagleboy99's Avatar
For the 19" I have to use a slightly different tire, but still within tolerance.
Old 07-05-23, 04:22 AM
  #54
budwom
budwom's Avatar
I just read that Nokian has had to basically abandon its huge factory in Russia due to the war...will set up large (but smaller than the Russian one) factories in Romania, also the U.S.
Old 07-05-23, 06:57 AM
  #55
1halifax
1halifax's Avatar
I was checking steel wheels as I was hoping I might be able to use the ones from my 2019 RX. I noticed one of the options is 18" that matches the model that I currently have. Has anyone tried?
Old 07-06-23, 10:44 AM
  #56
Deeps1
Deeps1's Avatar
this is the best formula. use it as winters for a few and then when the all seasons wear out you can end upwith a one tire solution all year around which is what i have done for the last 2 years.
ggebhardt (07-07-23)
Old 07-06-23, 12:14 PM
  #57
Eagleboy99
Eagleboy99's Avatar
Yeah, but that does not work in places where there are mountain passes. Up here you need 3MP snowflake tires October to April. And they do turn people back.
Old 07-14-23, 01:57 PM
  #58
stlblufan
stlblufan's Avatar
Default RX500 Tire Size
I am looking to get a set of wheels (i.e., a second set) for the winter. The stock size on my RX500 is 235/50R21. I am wondering if I can put a wider tread on for winter, like a 255? Thank you.
Old 07-14-23, 06:16 PM
  #59
Malky
Malky's Avatar
Isn’t it the other way around? Narrower tires are better for winter traction. You want wider tires for summer.
Old 07-14-23, 06:26 PM
  #60
stlblufan
stlblufan's Avatar
Yeah it's more about what is available. I can't find anything narrower than 255 in a 21".
Quick Reply: Winter tire options
