Winter tire options
Old 08-11-23, 07:17 AM
  #91
Criticalman
Criticalman's Avatar
Originally Posted by ggebhardt
The choice for 21” tires is limited.
If you really want frustration, try finding snow chains for the 21 inch wheels.
Old 08-11-23, 09:21 AM
  #92
Eagleboy99
Eagleboy99's Avatar
Konig makes a lot of large chain sizes for Europe.
Old 09-06-23, 08:08 PM
  #93
YVR2YYC
1st Gear
YVR2YYC's Avatar
Wink Rim spec for 5th Gen RX 350h winter tires
I am shopping for a winter tires + wheel set for my 350h. Any one knows the specs for 19" wheel? Will a set of 19" from 2015 RX fits?
Seems like there are not many choices for 235/60R19 winter tire. The only thing the local shop/dealer can order is Michelin X-Ice. It says it's suitable for EV. Does that mean the sidewall is much harder and if so how does that affect winter tires performance?
Thank you
Old 09-07-23, 04:12 AM
  #94
Carbuff2
Carbuff2's Avatar
Haven't investigated for 2023 RXs' specifically yet (sometimes the data for new models takes a while to show up)
But I have always had good luck with https://www.wheel-size.com/ to investigate wheel fitment.
Then, you should determine which tires are close to the same overall diameter and load rating with a site such as this:
http://www.powerdog.com/tiresize.cgi
Alternatively, you could just inquire on an online tire site, such as TireRack.com or DiscountTireDirect.com or SimpleTire.com
These sites also usually have areas where you can SEE how any wheel style they sell looks on your car.
One caution: I have found that many aftermarket wheels are more susceptible to corrosion from road salt, as the clear-coating on them isn't as substantial. YMMV!
Old 09-07-23, 04:32 AM
  #95
budwom
budwom's Avatar
Thank you
Still no options here that I know of, and I'll need some by November, but I suspect they'll appear pretty soon...heat wave here (90s for four consecutive days, hot by our standards) so winter tires are not yet a major topic.
Old 09-07-23, 09:16 AM
  #96
Eagleboy99
Eagleboy99's Avatar
PCM Tire (Quebec?) sells the Ovation WV-688 - 235/60R19 for $185/tire. Winter tread.
Old 09-07-23, 09:24 AM
  #97
toyotaman7
toyotaman7's Avatar
Where is Ovation from?
BTW, Michelin has winter tires for RX350 & 350h in 19".
Old 09-07-23, 09:38 AM
  #98
Eagleboy99
Eagleboy99's Avatar
China - like most offbrands. https://ovationtirescanada.ca/ I've had Sailun tires from China and they are not half bad.
Old 09-07-23, 09:44 AM
  #99
toyotaman7
toyotaman7's Avatar
For me if someone is spending close to $100K on a Lexus why would they want to save few hundred dollars on THE MOST IMPORTANT safety component of a vehicle???
Old 09-07-23, 10:30 AM
  #100
Eagleboy99
Eagleboy99's Avatar
Maybe you or I would not do it, but those offbrand tires are not that bad. I've had more issues with B F Goodrich than I've ever had with Sailun.
Old 09-21-23, 05:22 PM
  #101
seattleike
10th Gear
seattleike's Avatar
Default Winter Tires
As we get closer to winter I started looking for tires for my RX 500H. 235/50R21. Not many options. Anyone else looking?
Old 09-21-23, 07:47 PM
  #102
Eagleboy99
Eagleboy99's Avatar
Michelin Ice-X
seattleike (09-21-23)
Old 09-21-23, 07:51 PM
  #103
seattleike
10th Gear
seattleike's Avatar
Michelin Ice-X
I can only find it in a 20”. Does it come in a 21”?
Old 09-21-23, 08:42 PM
  #104
Eagleboy99
Eagleboy99's Avatar
https://pmctire.com/tires/michelin-x...-7335320551604 Note - CAD, not USD and not including discounts.
Old 09-22-23, 05:28 AM
  #105
paperthin
paperthin's Avatar
That is what I have been eyeing also (although in 19"). Costco also has it as well as canadawheels.ca YMMV.
Quick Reply: Winter tire options
