Recommended oil and change schedule
Old 04-01-24, 03:45 PM
  #256
IS3Fguy
IS3Fguy's Avatar
Default Oil change interval
How often do you change your oil? Do you follow the recommended oil change Interval which I believe every 10k miles or 16k km?
Old 04-01-24, 04:01 PM
  #257
CommodoreAmiga
CommodoreAmiga's Avatar
There's an extensive thread on this topic: https://www.clublexus.com/forums/rx-...-schedule.html
Seems that people mostly fall into two camps: Follow the maintenance schedule and change every 10k, or over-maintain and change every 5k.
Urlik (04-01-24)
Old 05-19-24, 05:14 PM
  #258
grhughes
grhughes's Avatar
Default Which funnel do you guys use for those who change their own oil?
Guys,
Did my first oil change at ~800 miles on my new RX 350 and when adding oil the filter wouldn't go much further than an inch before hitting something. This has to be the shallowest oil hole I've ever encountered. I was going to try one of the screw on funnels but the location of the oil add hole and the lack of room makes that impossible. I hate having to hold the funnel and pour at the same time as it's a recipe for a spill.
Old 05-20-24, 10:21 AM
  #259
StefanoS
StefanoS's Avatar
Originally Posted by grhughes
Guys,
I recently bought this one. It fits both of my Lexus hybrids and my Sequoia, as well. Makes oil changes much better. No more flopping funnels and it has a large throat, allowing me to pour 5 qt jugs of Mobil 1 easily with no spills. It threads in just fine with no clearance issues.
Amazon Amazon
Old 05-20-24, 12:20 PM
  #260
grhughes
grhughes's Avatar
Originally Posted by StefanoS
I recently bought this one. It fits both of my Lexus hybrids and my Sequoia, as well. Makes oil changes much better. No more flopping funnels and it has a large throat, allowing me to pour 5 qt jugs of Mobil 1 easily with no spills. It threads in just fine with no clearance issues. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Perfect. Can you post the link to the one you ordered as the link provided loops back to this post for me using Chrome.
Thanks'
Old 05-20-24, 12:23 PM
  #261
StefanoS
StefanoS's Avatar
Thanks'
That's odd... Go to Amazon and enter
APSG Locking Oil Funnel
Old 05-20-24, 12:29 PM
  #262
grhughes
grhughes's Avatar
Thanks. I'll give it a shot but the filter states it will not work on the RX350 so we will see.
Old 05-20-24, 12:30 PM
  #263
CAPTBob
CAPTBob's Avatar
As I mentioned in an oil change thread that was in the Hybrid section, I bought the funnel linked above that screws into the oil fill opening. In April when I changed the oil myself for the first time on my wife's RX350 (Turbo gas version), I discovered that the funnel won't screw into the oil fill opening. The plastic cover over the top of the engine that directs air to the rear of the engine and over the turbo prevents the funnel from screwing in. It still kind of works.and didn't leak but I couldn't screw it in. I wasn't sure how the plastic cover attaches to the top of the engine and, since I was getting the oil into the engine without leaking everywhere, I decided to explore how to remove the cover another day.
Old 05-20-24, 01:09 PM
  #264
Urlik
Urlik's Avatar
Thanks'
AdBlock is doing that. The site automatically puts an affinity code on Amazon product links which AdBlock stops.
Old 05-20-24, 01:10 PM
  #265
Urlik
Urlik's Avatar
Just yank it up and off.
Old 05-20-24, 02:28 PM
  #266
grhughes
grhughes's Avatar
Yea, nothing that tin snips can't fix
Old 05-20-24, 02:29 PM
  #267
StefanoS
StefanoS's Avatar
It will fit just fine. It also said that it would not fit either of my vehicles, as well but, it works. As new models come out, they really don't take the time to update the fitment. These work on all of the A25A 4 cylinder engines perfectly. There is no interference whatsoever.
Old 05-20-24, 02:30 PM
  #268
grhughes
grhughes's Avatar
Thanks for the info. I'll know more tomorrow when it arrives and I'll update this thread.
Old 05-20-24, 02:32 PM
  #269
StefanoS
StefanoS's Avatar
As Urlik stated.....the cover just pushes into a couple of rubber grommets. You simply just grab the two forward facing corners and lift up......yank it off.....piece of cake.
Urlik (05-20-24)
Old 05-20-24, 02:33 PM
  #270
grhughes
grhughes's Avatar
Thanks.
Quick Reply: Recommended oil and change schedule
