Recommended oil and change schedule
#286
autotech13 (06-06-24)
#287
It's just the natural advance of technology. Engine technology is world's better than it was and synthetic oil allows longer intervals. 10k is actually conservative. I've watched and paid attention all these years.
#288
You really think that a 10k oil change interval sells more cars, especially when the maintenance interval is still 5k?
#290
#292
Budwom, I am a 5k oil changer but I have no issue with 10K people who go by Toyota's guide. My question, why do Toyota and many other manufacturers say transmission fluid is good for the life of the car? Most good mechanic's say change every 50 to 60K. Lot's of people have had transmission issues way before 150K and many would probably not have had those issues had they ignored the manual and done it earlier. Then Toyota gets to sell a new one off warranty.
grhughes (06-05-24)
#293
Oh boy,don't we all love OIL TOPICS? ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
My experience: Back when manufacturers used & recommended mineral oil, I actually EXTENDED my change intervals by 20%...but I used that new-fangled SYNTHETIC oil. I have always used synth in our 1980's turbo sports cars BTW...and when we rebuilt that engine (only because it was removed to rebuild the trans) the bearings were better than most.
You can't tell how much useful life is in modern oils just by looking. Some looks 'dark' within a few hundred miles, other brands do not. I notice that SOME YouTubers 'taste' it. Yuck.
Having an oil analysis is the best way to determine 'remaining life' for your particular operating circumstances. I'd LOVE to see a comparison of a 350 and 350h oil with the same mileage (since the hybrid runs its engine intermittently).
Who remembers the sludge issues Toyota had in the early 2000s? Chrysler, too.
https://forums.edmunds.com/discussio...dge-settlement
I'll conclude by suggesting that concerned owners monitor BobIsTheOilGuy.com..perhaps ask there to broaden the experience base.![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
I also watch Lake Speed Jr.'s Motor Oil Geek youTube channel. https://www.youtube.com/@themotoroilgeek
#295
I am true believer of full 10K service oil change, which I did with 2GR and even I understand if you have inline 4 with hybrid I would assume 10K is fine still.
What has me this time is Toyota being new to turbo engines with the high heat outputs and watching the car nut explain it.
#296
All I know is that when I look at Consumer Reports info on used cars going back eight years, I just don't see Lexus transmissions listed as a failure item...The info goes back eight years, and in all years the RX has the highest rating, "much better than average."
Having said that, if one is really concerned, you can have an independent mechanic do one of those quasi fluid changes for not a ton of money as I did with my Volvo....but I just don't see it as something I'm going to fret about.
#297
I use to own a 1996 Impala SS. The transmission was a known weak spot and often failed before 50k. Many owners tried early and often fluid exchanges, but there seems to have been no real difference in the failure rate between those who changed more often and those that followed the factory internal.
Just because an engine or transmission failed, does not mean the fluid change interval is at fault.
Everyone that drinks water will die...
budwom (06-07-24)
BBoyM3
RC F (2015-present)
04-24-15 07:47 AM
