Roof cross bars with panoramic roof.
My dealer states that roof cross bars cannot be used with a panoramic roof. Is this correct or has anyone used cross bars on a panoramic roof without any issues?
It's for a prior generation of the RX but covers the topic in some detail. On earlier versions of the RX with a panoramic roof, dealers routinely echoed what your dealer is telling you. That didn't stop some owners from finding novel ways around this limitation.
Pierre2023 (05-01-23)
Some cars simply cannot be fitted with the pano roof and roof racks. But Thule and Yakima make all sorts of hotch-mounted things like ski/snowboard racks, etc. Now if you could only get a hitch...
The following 2 users liked this post by Eagleboy99:
FordBoy33 (12-30-23),
Thanks for your comments. I did find someone who installed Thule crossbars with a panoramic roof. I was hoping to determine if Lexus’ reluctance to do so was structural or safety related or simply functional ie roof cannot open. The reason for my inquiry is that I find the trunk space limited and I would want to use a roof box/carrier when on road trips. I would remove the carrier and possibly the crossbars when not required. I could live with not opening the roof but I wouldn’t want to jeopardize the safety of the occupants if this caused a structural or safety risk. Does anyone know if crossbars cause a structural or safety risk with the panoramic roof?
Urlik (05-01-23)
Regards
The Lexus.ca website acts differently now, you can't add the cross bars to a trim with the pano roof anymore, but you could when I ordered mine, it'll be interesting to see what happens whenever it shows up since it's in my config summary from when I ordered.
Now if you go to the site it won't give you the option if you have a pano roof trim level, and if you change from a model without a pano to one that does have a pano, it removes the cross bars (and doesn't it you just change to another trim without a pano roof.
Pierre2023 (06-01-23)
Thank you Mr Biebs. If you can please let me know once you take possession of your vehicle if the do provide the crossbars and if they do, if they negatively impact the opening of the pano roof.
I am doing a research for my RX500h roof bar options and found this thread.
If you got this information from https://www.rackattack.com/car-rack-...ions/lexus/rx/ --- I think the images were for a NX not a RX --- check its c pillars.
FWIW, I think there are two options:
1. Try the Lexus OEM Rx Crbr (PT738-48900) --- it's not expensive and potentially return-able to your local parts store.
2. Thule is now showing "fit confirmed" roof bar options for 2023+ RX 5-dr SUV, but it's not available online yet: https://www.thule.com/en-us/roof-rac...xed%2520points
I mainly want to put on ski and bike racks --- nothing really heavy like a box. Will wait a bit for anyone to try out the Thule solution.
"Cars with sun roof: Due to the racks' low fit on the vehicle, it may not be possible to open the sun roof when the racks are installed. Please check clearance before opening your sun roof"
Roof rack for panorama glass roof?
I have a 2023 350h with a panorama glass roof. Roof rails are included as part of the package, which is ironic because the Lexus crossbars are incompatible with the glass roof. I believe the crossbars will work as long as I don't open the roof. I need the crossbars for a ski rack in winter. Does anyone with a panorama roof have a ski rack? If so, is it aftermarket with a high enough clearance for the panorama roof? Is anyone risking it by using the Lexus crossbars?
You can lower the center section only and run your ski bag through it, while still carrying 4 people and all the gear in the car.
I believe the issue with the pano roof is the foot on the crossbar(s) has to be quite a bit taller; ran into this with my daughter's Tucson and we had to wait a bit for an OEM set of bars to become available- hers was the first year of that new body-style, too. I do know there were a couple of instances where pano-roof people put the standard bars on and accidentally cracked the glass when they opened it up all the way.
