Premium fuel required on the RX350?
Old 10-26-23, 06:15 AM
  #61
autotech13
autotech13's Avatar
Why not meet in the middle, use 89 octane!
Old 10-26-23, 07:41 AM
  #62
lexusnyca
lexusnyca's Avatar
Costco doesn't sell mid-range.
Old 10-26-23, 07:58 AM
  #63
WellsB
WellsB's Avatar
You could pump half of each in to mix your own.
Old 10-26-23, 08:07 AM
  #64
CommodoreAmiga
CommodoreAmiga's Avatar
The most useless of the octanes, imo.
Run what the vehicle calls for.
If you want to ignore the requirements and "be cheap" then just be cheap and use 87.
89 is a no-mans-land of being not quite cheap enough but also not quite good enough.
The following 3 users liked this post by CommodoreAmiga:
budwom (10-26-23), neilsarkar (03-20-24), WellsB (10-26-23)
Old 10-26-23, 08:22 AM
  #65
johnhey
johnhey's Avatar
This is not about being cheap(not wasting your money is not equal to being cheap) , it is a technical discussion that using 87 instead of 91 will hurt your engine (for real) or not.
many people do not care about losing 5 HP if using 87.
as I mentioned in my original post, many people use 87 on their BMW and Mercedes that requires 91 and have 0 engine issue.
the discussion is that if Lexus the same.
WJ123 (02-11-24)
Old 10-26-23, 09:09 AM
  #66
WellsB
WellsB's Avatar
Some BMW's call for a minimum of 89 octane fuel.
I've seen older cars that call for 87 knock on that grade, but not on 89.
Old 10-26-23, 09:32 AM
  #67
ggebhardt
ggebhardt's Avatar
Today’s modern engines have sensors that adjust for lower octane. You might lose a few ponies but not enough to notice.
Carbuff2 (10-26-23)
Old 11-25-23, 07:05 AM
  #68
johnhey
johnhey's Avatar
Lightbulb *Technical Discussion* 2024 RX vs Highlander Engine and Fuel Type
I have checked the user manual for 2024 RX and Highlander, as you see in the images below( taken from 2024 User Manuals left is RX, right is Highlander), both engines are identical even bore and stroke.
but then when I look at fuel type, RX requires min 91 but Highlander is 87.
so wondering why different fuel type when two engines are the same, is it because of possible different compression ratio like RX turbo pumps more air into engine so that 91 is required so fuel is not ignited premature?
Note: This is technical/mechanical discussion, so please refrain from posting advice etc
The following 2 users liked this post by johnhey:
EBone (07-02-24), Wait4Vtec (11-27-23)
Old 11-25-23, 08:08 AM
  #69
WellsB
WellsB's Avatar
Highlander has 265 hp and 310 lb-ft of torque.
RX350 has 275 hp and 317 lb-ft of torque.
This tells me that the RX350 is optimized for 91 octane gasoline. I believe the optimization is on the software tuning, probably allowing some combination of more boost, more spark advance, and/or more aggressive cam timing to increase compression.
Old 11-25-23, 08:30 AM
  #70
LambrosCan
2nd gear
LambrosCan's Avatar
Default Absolutely not required.
Although the rx350 is a turbocharged 4 cylinder, it will run without any issues with regular fuel.
Old 11-25-23, 08:38 AM
  #71
oneround
oneround's Avatar
Just a small complication in the issue is the difference in the RX models with Turbochargers. In this case I am assuming the tuning difference is to better match the electric motors.
Engine specs
Old 11-25-23, 10:25 AM
  #72
BLUKTY2
BLUKTY2's Avatar
I agree that is is merely software tuning. Both of these vehicles have the identical engine.
Old 11-25-23, 10:31 AM
  #73
BLUKTY2
BLUKTY2's Avatar
Engine specs
I believe that there is a typo in this chart. The RX350 FWD/AWD has the same 2.4L engine as the RX500h AWD, not a 2.5L as shown. 2,393 cm3 equals 2.4L.
Carbuff2 (11-26-23)
Old 11-25-23, 10:58 AM
  #74
oneround
oneround's Avatar
Agreed. I never even noticed before. Wonder if Lexus has and doesn't care, or if they haven't found the error yet?
Click download PDF on the product specs line of the webpage.
Old 11-25-23, 12:17 PM
  #75
jahnjva
jahnjva's Avatar
Engines are correct but the chart is not showing the hybrid contribution to its horsepower and torque numbers.
Quick Reply: Premium fuel required on the RX350?
