Issue with dash separation
#151
ncRXhybrid (09-21-23)
#152
10th Gear
Dash failing again
After having mine fixed on 07/31, it seems to be falling again. Taking it in for the 10,000 appt on 10/14 and hoping to have a more permanent solution. Super annoying.
Wait4Vtec (10-08-23)
#153
I took my 2023 RX350h into the dealer for the 6 month checkup. The dash trim started to separate from the upper dash a few months after I purchased the 350h this year.
I explained the separation and the dealer in Oregon was familiar with the problem. They removed the clips and "installed expansion" to the clips and put the clips back on. Here is their description of the service: SERVICE: INTERIOR TRIM
DESCRIPTION:~|~CUSTOMER STATES INTERIOR TRIM IN PASSENGER SIDE IS COMING LOOSE PLEASE CHECK AND REPORT ~|~CLIPS WILL NOT HOLD DUE TO POOR FITMENT/MANU FROM FACTORY ~|~CONFIRMED AS DESCRIBED. PHOTOS TAKEN BY S/W REMOVED CLIPS AND INSTALLED EXPANSION SO THAT CLIPS WILL HOLD PANEL TO DASH MAIN PANEL. 23 RX DASH COMING APART REPAIR OP 550991 .4 HRS T1=62 T2=41 PART #55474-0E150C3
Wait4Vtec (12-16-23)
#154
Sounds like they have a fix now that doesn't require tearing the dash apart.
#155
Sat in a 2024 and the dash was secured well. The newer bottom panel seems to sit further back, about a cm+ back vs the top dash piece.
Hard to see from the angle, but the newer panels fit better, maybe they fixed the clips.
#157
A few people have had dash separation problems and there is a thread on this problem in this forum. It goes back a few months; a search should bring it up.
Mjkelly (04-06-24)
#158
Here you go (prior dash separation thread): https://www.clublexus.com/forums/rx-...eparation.html
#159
Seems to have only been an issue for a few months of production in 2023. Our dash garnish needs to get fixed as well.
Mjkelly (04-06-24)
