Is it possible to play mp3s from a USB flash drive on a 2023?
I am using a Samsung 64G. I had to format it to Fat32 otherwise it would not work. I put mp3 on it and it is recognized by my 350h. The first time you insert it, it may take a minute to recognize and read it.
I put my FLAC, some MP3 and AAC files on a 256gb usb drive and can play them all. The key is to format the drive to FAT32 not exFAT and be patient while the car reads the folders.
FMY421 (10-06-23)
The USB is formatted for FAt32, but the car doesn't read it (I tried FLAC and WMA as well, nogo) It works fine on my Corolla, so I'm pretty sure it's the Lexus. I'll reach out to the dealer.
My wife, who's the driver, plays MP3s off her phone (she has a few thousands there), so she's not really bothered about it, so it's not a major issue.
Thanks for the replies, everyone!
Mine works with a 256gb drive. Check the steps above. My drive has around 12,000 mp3 files on it and it works perfectly so I KNOW this works.
Look here
DaveLissa (12-02-23)
DaveLissa (12-01-23)
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Check the post above #8 from me.
Look here
Look here
It still won't play my 32GB USB3.0 drive, but I will test further. I work in IT and have plenty of USB drives lying around. On the 32GB drive, I have about 1,500 songs.
It COULD be something to do with the physical dimensions of the 32GB, it's small, but may not fully fitting into the USB port, so never registers on the RX.
My Toyota re-reads the USB drive when the vehicle has been powered off for a while, so I have to wait about 10 seconds before it plays. Hopefully that's not the case with the RX.
1) It should be formatted to FAT32 as noted above. FAT32 can hold 64k files.
2) You can only have a max of 3,000 folders (i.e., "albums") at the top level.
3) You can only have 255 files per folder (255 songs per album)
4) You are limited to 9,999 files all together (I think this includes folders/albums also)
So I wonder whether auebank can actually "play" all of the 12k files, even if they're "seen".
FAT32 (32-bit File Allocation Table), is file saving format used to save files on computers. FAT32 itself has some limitations, not related to music or Lexus, but intrinsic to the file system.
Wait, I see where you're getting at! I meant the file size of a single file is limited to 4GB. Let me fix my earlier post.
You can review further here if you're curious: www.pcmag.com/encyclopedia/term/fat32
Urlik (12-02-23)
LSSAH
09-08-20 08:05 AM
