Collated listing of additions we'd like to see to Lexus multimedia
Old 06-09-23, 05:59 AM
Urlik
Urlik's Avatar
I got your first and third, I want to check something in the manual when I get back home for your second.
Old 06-10-23, 08:05 AM
Eagleboy99
Eagleboy99's Avatar
What is #1 in the original list? You mean the radio volume does not stay at the last setting?
Old 06-10-23, 08:15 AM
Urlik
Urlik's Avatar
From post #12: "The car currently remembers the last volume setting just like radios used to in the past when they had analog volume control. The nice thing about having the ability to set a starting volume is if the last driver had the music cranked when they shut down the car, you don’t blow someone’s ears out when they start the car."
If you're someone that really never messes with the volume, you just set the starting volume at that level. There is also no reason they couldn't make it an option to set a starting volume and if you don't set one it defaults to the last volume.
Old 06-10-23, 08:26 AM
Urlik
Urlik's Avatar
Originally Posted by superjer
* Access other information through an app menu - weather information can be brought up using the voice assistant but there should be an app or other way to bring up directly
I added this to the top post. I'm thinking the reason it is only voice command is because it requires the Intelligent Assistant from the Drive Connect subscription. The manual doesn't talk about that command at all anywhere like it does other commands so i can't confirm.
Old 06-10-23, 09:21 AM
Yobuda
Yobuda's Avatar
In Google Maps you can hit a route preview button that will zoom out and show you the traced route.
Can't find that function on native navigation...
Old 06-10-23, 09:42 AM
Urlik
Urlik's Avatar
On the list.
Old 06-16-23, 02:59 PM
Urlik
Urlik's Avatar
Updated to add kph to mph gauge cluster.
Old 06-17-23, 09:53 AM
Yobuda
Yobuda's Avatar
I find it annoying that when you unlock the car just to get something out of the back or whatever, the side mirrors fold out.
I prefer the scheme where the side mirrors only fold out when you start the vehicle or push the button if doing cleaning, etc.
________________________
RX500h F-Sport Performance
Old 06-17-23, 09:58 AM
daryll40
daryll40's Avatar
And I’m the complete opposite. I like the visual confirmation that the vehicle is definitively locked or not locked.
socamille (06-28-24)
Old 06-17-23, 10:38 AM
Urlik
Urlik's Avatar
I have the same feeling but still no reason this couldn't easily be an option. Added.
Old 06-17-23, 01:10 PM
Yobuda
Yobuda's Avatar
Yeah - I get that - always relock when doing that if I'm not going to be around the vehicle.
If they enable the auto-lock feature, confirmation issue solved!
- The ability to have the car auto lock when no key is in range (post #4)
Old 06-21-23, 04:24 AM
Carbuff2
Carbuff2's Avatar
Don't know if this would be controllable by the multimedia screen
But I just realized that the passenger-side outside rearview mirror on our RX500h does not have the ability to Auto Dim.
A SEARCH here saw several discussions on other models, where owners were also grousing about this seemingly overlooked capability. (Chip Shortage?) <<SIGH>>
Old 06-21-23, 04:58 AM
Urlik
Urlik's Avatar
That is a hardware issue, it would require a different mirror and wiring harness in the housing. It doesn't bother me but I also set my side mirrors the way that avoids any blind spots so the lights behind me don't hit the mirrors anyway. https://www.caranddriver.com/feature...d-blind-spots/
Old 06-21-23, 05:10 AM
toyotaman7
toyotaman7's Avatar
I believe as cost saving the auto dimming passenger side mirror has been removed form RX and NX; regardless of trim and options.
Old 06-21-23, 08:58 AM
alextv
alextv's Avatar
For this car not to have a split screen is technologically backwards. It is not an oversight and it probably is hardware used will not support. Makes me wonder what else is skimped on and whether I want to trade my ES300h for this. It is good knowing the downsides without surprises thanks to this forum.
The following 2 users liked this post by alextv:
superjer (06-21-23), Urlik (07-01-23)
Quick Reply: Collated listing of additions we'd like to see to Lexus multimedia
