Hesitation on start on RX350 (non hybrid)
#46
Rx350 - Hesitation TSB
I saw this TSB pop up, it is for ICE RX350. I feel this has occurred a few times where I be turning out in front of traffic there is literal pause before when the power even kicks in. I always wrote it off as it me slamming on pedal and there slight delay from turbo etc. However on one occasion I had stopped to get ticket at parking lot and then went to go it took more then second to go, it was enough time that I looked to see if I was on hold or in park. That has only happened one time and the other instance is if I have to slam on it to turn in front of traffic, but that doesn't occur all time. I can say it definitely not transmission hesitation felt in prior generation in 2016 or even transmission delay feel. It does feel like either turbo lag/delay or engine not getting communcation via ECU to apply the throttle at all.
Next visit I will get more details, I was just seeing if anyone had this applied yet or could pull actual TSB.
Bulletin Number: LSB005623
Replacement Service Bulletin Number: N/A
NHTSA Item Number: 10247797
Date Posted: 11-02-23
Component Name: 061600 ENGINE AND ENGINE COOLING: ENGINE: ENGINE CONTROL MODULE (ECU/ECM)
Make: LEXUS
Model: RX
Year: 2023
Date Added: 12-25-23
Summary: TSB: Some 2023 model year RX 350 vehicles may exhibit one or both of the following conditions: ?Hesitation when accelerating from a stop. ?Non-linear acceleration from a stop or rolling stop with steady throttle. The Engine Control
RECORD_ID: 4431843Bulletin Number: LSB005623
Make: LEXUS
Model: RX
Year: 2023
Longevite1 (02-05-24)
#47
I have Neuropathy and tend to be a "2-foot" driver. I can't move my gas foot fast enough to hit the brake, in an emergency. Ergo, I brake with my left foot. If you happen to have your foot barely touching the brake, when you go to accelerate, it will "bog" a bit and there will be a warning on the instrument panel that brake and accelerator are being pressed simultaneously.
#48
Make: LEXUS
Model: RX
Year: 2023
Make: LEXUS
Model: RX
Year: 2023
#49
I also brake with my left foot, been doing that since I was a kid on a farm. You get a much faster response, but do what feels comfortable for you.
#50
This is exactly what it is it like, there is such delay where you have a min to think like what's going on here. Foot was no where near the brake and was in regular mode. It was enough that it spooked me as I had given myself enough distance to turn in front of the car and this almost caused me to get hit. I need to get more details if this is software update or replacement of something. Because everything else is fine expect that rumble vibration I get between first and second gear sometimes which makes me feel like sometimes I am driving old hybrid as it feels like ICE to electric motor.
#53
Have a 2023 RX350. Have a hesitation issue when accelerating from a stop or slow down. Been to the dealership twice they are blowing me off. I have a Lexus bulletin from 11/23 stating the problem and the fix if replacing the PCM. They will not do it. They are replacing my regular gas with premium. Ridiculous
#54
Those papers are from November of 2023. There has been a simple update since then that should fix the issues. If they won't apply the update then go to another dealer. Also, the 2023 RX's require premium gas not regular. If you're using cheap gas that isn't premium you are going to see issues.
#55
#56
We ended up taking ours in to the dealer and of course they could not duplicate the issue. I started thinking about it and wondered if all of the proactive driver assist functions were the issue, basically playing nanny and not allowing us to pull out into what it felt was cross traffic. I disabled a bunch of them (need to verify which ones specifically) and haven't had the issue since.
#58
