How to set up split screen?
The only time I see a split screen is when using Android Auto and it is automatic. For example, if you are using Google maps or Waze, that will show up and a split smaller window could be your audio feed. If you press on the Google maps icon while it is in split screen, it will go to full screen. All the spilt screen functions in Android Auto are mostly automatic with the ability to go full screen until you select another app.
more info in post #31 in this thread: https://www.clublexus.com/forums/rx-...timedia-3.html
Marcelgermain (07-13-23)
Using AA split screen is nice if you want to see an audio source other than from the car but if you want to be able to see the radio or XM from the car you can't. When they designed this system they saw that big 14 inch screen and opted to have only 1 source there and will probably never change.
Minhbann
NX - 1st Gen (2015-2021)
11-01-21 06:19 PM
