How to display tire pressure?
Old 07-19-23 | 12:17 PM
radajg42's Avatar
radajg42
10th Gear
Default How to display tire pressure?
Is there a way to bring up the tire pressures on the dash display and/ or the HUD? I have a 2023 rx350h. Thanks. Great forum/club.
Old 07-19-23 | 01:25 PM
lexusnyca's Avatar
lexusnyca
The following 2 users liked this post by lexusnyca:
budwom (07-19-23), Carbuff2 (07-19-23)
Old 07-19-23 | 01:55 PM
budwom's Avatar
budwom
find a boring, rainy day and slog thru the videos...I learned what I needed to learn....
jpspchen10 (02-28-24)
Old 07-19-23 | 01:59 PM
Carbuff2's Avatar
Carbuff2
You maybe required to have the car stopped/stationary for many of these menus to come up...(Safety)
Old 07-19-23 | 03:32 PM
ggebhardt's Avatar
ggebhardt
Under vehicle and then Tire Pressure. It is my default when not on the NAV screen
Old 07-19-23 | 05:04 PM
Urlik's Avatar
Urlik
I went to that menu the other day when I had the wife’s car and it didn’t show the pressures. I have the feeling they didn’t set it at the predelivery inspection. I’ll need to find some time to look at it more.
Old 07-19-23 | 07:24 PM
radajg42's Avatar
radajg42
10th Gear
Default tire pressures
I've gotten it to show each pressure on the big screen intermittently and can get it on the lexus apt on my mobile phone. I can't figure out how to get it on the hud or on the instrument dial display. Keep watching the videos but I must too dense or maybe it can't be done.
Old 07-20-23 | 01:39 AM
ggebhardt's Avatar
ggebhardt
On my 350h, when hitting the vehicle icon, tire pressure is listed. Note, it will not show tire pressures until the vehicle has moved, not at start up. I assume it takes a few revolutions of the tires for the sensors to kick in. From the factory, your tires will be over pressured. Mine were in the low 40 psi range.
I do not think tire pressures can be displayed on the HUD.
Old 07-20-23 | 03:21 AM
radajg42's Avatar
radajg42
10th Gear
We have a Subaru that has a toggle switch on the steering wheel that will bring up the tire pressures on the instrument panel but as you said not until the car has been driven a short distance. The pressures on the Lexus apt that I can get on my phone are not always current and in fact usually several hours later. Much easier to use on the Subaru but not a big deal. There is so much more customization that the Lexus has , just a longer learning curve for me. HUD display of pressure probably not possible. My tires, 21" wheels, were also high from the factory, all 41 psi. Guess that is not an item dealers check on pre-delivery inspection and in my experience with different new cars, most dealers neglect this also..
ggebhardt (07-20-23)
Old 10-27-23 | 11:56 AM
pray84's Avatar
pray84
10th Gear
Default How to see the tire pressure?
Does anyone know how to see the tire pressure? When I go to the tire pressure monitor I just get the screen below but it doesn’t show the pressure for each tire. I can only see it on the Lexus app.
Ascho (02-23-24)
Old 10-27-23 | 03:57 PM
Bentru's Avatar
Bentru
you have the information under this screen
Tire pressure
ucfjef
05-04-23 11:23 AM
ejb222
02-12-14 11:42 AM
hillrnnr9
12-05-12 04:02 PM
Jace7
01-06-07 04:25 PM
TOPSPEED
06-21-02 06:19 PM
Quick Reply: How to display tire pressure?
