Power Liftgate issues?
When the door is in “error” mode .. and I press the “close” button (via remote, dash board, or remote fob buttons) and I get the “two beeps”, the door will not move. When in this “two beep” error code/mode .. I have to manually push the door down to the close position. When I manually push the door closed to the “closed” position .. I do not get the usual latched\beep\lights flash acknowledgment
It could also use the parking sensors.
For me the 2 beeps most of the times means that I'm standing too close to it and anticipates to hit me, so it stops and beeps twice.
I got it again and step back in order for it to close.
There are object sensors on each side of the lift gate you can see in this parts breakdown: https://parts.lexusofwesleychapel.co...09.html#84280D
I am tracking successful and failed closures. For some reason it has gotten better than 40% failures (wish I captured earlier data) Some data from 3/30 2 Good, 4 Bad, 3/31 8 g 2 bad, 4/1 3 G 0 B, 4/2 3 G 0 B, 4/3 3 G , 1 B. All presses are done identically, phone and key fob in my pocket and me standing next to the bumper pressing the switch.
I´ve had the problem when the rear door is open and I press the close and lock button, just beeps and nothing happened. I was at a busy supermarket and thought I would not be able to close the door.. Tried it several times and never closed. Finally I realized I could use just the close button and then lock with key fob and that worked. It has not happened again.
autotech13 (04-05-24)
We now walk 15 feet away after pushing the button. Turn to verify...
It DOES close, then.
The best I understand from the manual and posted Lexus videos is the purpose of this switch is for loading or unloading the hatch. You press the button and then grab stuff that is in the car or load the car and then you walk away. When it works correctly I have no issues. I get one beep then a second beep that starts the count down. If I walk away any time prior to 30 seconds the sensor recognizes this and closes the hatch and locks the car. When it fails I get either one beep and nothing else or one beep and then two quick beeps and nothing else happens.
Urlik (04-06-24)
Just took delivery of a 23 RX premium+. Anyone having power liftgate issues? I can “open” the tailgate with the remote, the key fob, and the dash button .. no issues opening. However; randomly (about 60% of the time) the liftgate will not “close” I can press any of the button/sources and all I get is two beeps .. I have to manually close the gate. Worked fine at delivery, checked with service isle and previous owner did not report this issue during their 5 months and 4k miles of ownership. Dealer reset the radio/BCM .. worked one or twice .. then issue returns. Leave it sit overnight and it resets itself .. then the issue returns (randomly) after a couple uses..
Thoughts?
RESOLVED: Dealer confirmed the left bump stop strip was defective. Generated some code that helped identify the left side bump stop was defective. Replaced\resolved 10/6/23
Thoughts?
Same problems here, close and lock button on liftgate 100% does not work at all and it's not even debatable. Doesn't matter if I press and wait, stand there, walk away.. door just beeps and NEVER CLOSES.
My experience is that I push the button, hear ONE beep, then about ~2-3 seconds later I hear TWO more beeps, and that's it. The door never moves even after several minutes. This happens even if I press the button and then sprint away from the vehicle. I just hear the failure beeps as I'm running away. To be clear I've tried this at least 40 times and the litigate has not successfully closed even once. One beep, two beeps, FAIL, no matter what I do.
Edit: Adding that the regular close button works fine every time I've tried it. Only the close & lock button is useless.
Curious to hear what the rep has to say about this. I also have occasional "no close" when using the close and lock button and haven't been able to figure out why. No rhyme or reason to it.
The dealer tried to tell me nothing was wrong. I spent over three hours there and had a similar failure rate. How they are not demanding a fix from Lexus is beyond me. I'm not sure why any people that have this issue is accepting this? When it works, it is a nice feature for loading and unloading stuff. Key stays in pocket, hit button, unload and walk away.
I have other crazy Bluetooth issues as well that the dealer is also telling me nothing is wrong.
