Headlights Stay On in Daylight in AUTO?!
10th Gear
Hey guys,
Happy New Year! So what am I doing wrong?
I have DRL set to ON and on the stalk I have the lights set to AUTO but I notice that the headlights just stay on all teh time with the DRL.
I even have the light sensitivity set to teh darkest setting.
Thank You!
Thank You!
Mine are set the same way as yours and only the outline running lights come on in the daytime. I tried turning the DRLs off, and the running lights then only come on when the switch is moved to that position, and dimmer than when in DRL mode. I don't know if there are other settings that might cause the behavior you are seeing or if there is something wrong with yours.
You will see the green headlight indicator when the headlights are on. If not and in auto, itthe LED running lights. They are pretty bright.
Carbuff2 (01-01-24)
swaangin
03-03-23 11:15 AM
ThChinaman
11-05-12 02:03 PM
