I have the RX350h. The front seats are supposed to have angle adjustment but it does not seem to work in my car. My previous 2 cars *RX350 and IS250 2007" both have this feature. The manual also indicates that there is angle adjustment but it does not seem to work. Wondering if others have the same issue or are able to adjust the angle. Refer function (B) below.
My 350h easily adjusts the seat back angle. It is the vertical elongated button (D) when pushed forward of backward. If yours is not moving, take it to the dealer and have the check the motor connections or switch.
The "D" works fine. It's "B" that does not seem to work. It only lifts/lower the seat/cushion (like "C"). "B" is suppose to change the angle of the cushion.
Our (B) works fine. Is it possible that the front of the seat is all the way up? Push the rear side of the switch down, see if that affects the cushion angle.
I adjusted the front of our seat upward to allow my eyes to be further from the digital rearview mirror, thus keeping the image in better focus.
How high up is your front cushion able to raise? Mine doesn’t seem like it’s going up as much as it should. It’s not near as high as the video shows, mine’s about an 1”, 1 1/2” at most. What’s wrong?? Highest my front cushion will raise.
I think that's normal. May I know which video you are referring to?
