Dead 12v battery Incident (merged threads)
#601
I have the same eyelet harness as jahnva, permanently attached to both of my 450h+ model's batteries in the cargo area. I also have a couple of charger plug extension cords to provide a little flexibility for charging, whether it is inside or outside the garage. Both batteries have a monitor attached to them, as well, so that I can see the resting SOC at any time on my iPhone. I don't always use the NOCO charger unless the SOC is very low. Putting the vehicle in READY mode for 30 to 45 minutes is enough time to bring the 12v battery up to a decent state.
#602
Stefanos, I have a volt meter in my 9 volt outlet up front by the wireless charger. Do you think that gives an accurate reading compared to your battery monitors? I figured those monitors add to the parasitic drain but it's probably minimal. My volt meter measures only 11.8 with just accessory mode, when the car starts it jumps up to 12-14 volts. I havn't charged the 9 volt in about a month and although 11.8 sounds low, it never has an issue starting. After I charge, it jumps up to the mid 12's but after a few days it settles back to 11.8 My guess is the battery is partly desulfated and will quit in a year or so.
#603
CCGS has a much more exotic setup. I have an optional eyelet ($15-20) permanently attached to my battery. When I want to charge, I just connect the charger wire to this eyelet and run the wire out my right rear window.
NOCO GC008 X-Connect M10 XL Eyelet Terminal Accessory Genius Smart Battery Chargers
Markfm (Yesterday)
#604
Running it out the window was what I planned on doing, until the fancier option showed up. CCGS is in Canada, and from the looks of it, that part is like $700 or more LOL I'd rather spend 70 on the Noco5 plus the accessory you mentioned and go that route. I also don't need to charge the battery every night, my wife drives it almost daily. Just on the stretches of time where we know we don't drive it for 2-3 days.
jahnjva (Yesterday)
#605
When you say ready mode, do you mean starting the car and letting it run for 30-45? Or is READY mode something else? I really don't want to have to let her car run LOL
#606
The 12v battery is charged from the Lithium battery pack in both of my cars. When you press the POWER button, the instrument panel illuminates and shows READY in a green rectangle. This is when your 12v will charge.
#607
Can not do this if garaged as ICE will come on to charge the hybrid battery.
#608
#609
![Yikes!](https://www.clublexus.com/forums/images/smilies/yikes.gif)
I keep the rear window cracked slightly open, and bought a 6 feet eyelet cable to run to the window from behind the rear-set (without drilling holes in the car etc). If you are interested in a hole in the car, you'll find posts by SMartin and others in the NX subforums who have taken that much trouble - making the hole in the plugin-charging inlet plastic.
Folks here are talking about the 450H+ - if there is more than 30 % charge in the traction battery (say, 40 % or more), the ICE wouldn't come on, but the heat-pump will, unless you switch those off from the app. For any 350H (or 500H, now that there is at least one reported here), yes, there may be a good chance of the ICE coming on.
#610
I talked with my wife tonight, and she wants to hold off on buying the Noco trickle charger. We are going on vacation next week and will be gone 8 days. This will be dead within 3, so when we get back, I'll have to get it jumped, then bring it to my dealer and from there, it's in their hands. My wife would rather pursue the lemon law than risk this being her long term car and having to plug in a battery every 2-3 nights. That shouldn't need to happen on a $76K SUV. We've never had that issue with any Toyota Hybrid over the last 8yrs that we've owned them. First time in a Lexus, and disappointed so far. The car itself is fantastic, but these ghost drain issues are bonkers.
In the end, it's her SUV, not mine (I drive a Wrangler 392) so if she doesn't want the hassle of plugging it in, then I will do everything in my power to get Lexus to fix this properly, or they'll buy it back. I have Lawyer friends LOL
The following 3 users liked this post by GeneralKlinger:
#611
The following 2 users liked this post by wrinkle:
autotech13 (Today),
CCGS (Yesterday)
clp71220
07-30-24 06:13 AM
skwinter
04-03-15 11:19 PM
