Dead 12v battery Incident (merged threads)
Old 08-18-24, 12:33 PM
  #631
pcm888usa
pcm888usa's Avatar
To clarify, my 3rd battery solved the problem.
E46CT (08-26-24)
Old 08-18-24, 02:29 PM
  #632
WellsB
WellsB's Avatar
I would never assume a battery is bad just because it died, nor insist that a battery be replaced if it tested as good. That is a knee-jerk reaction and an indicator of a parts-changer, rather than a skilled mechanic.
Our battery died twice. Neither time was the battery at fault, and it tested good both times, after being recharged. It hasn't died again, since.
The following 2 users liked this post by WellsB:
Carbuff2 (08-18-24), StefanoS (08-20-24)
Old 08-18-24, 03:00 PM
  #633
deaded
deaded's Avatar
What was the cause of the battery dying?
Old 08-18-24, 03:03 PM
  #634
WellsB
WellsB's Avatar
The first time was due to leaving it in ACC mode too long. The second time was due to excessive parasitic draw. I believe the parasitic draw was due to the keys being stored too close to the vehicle. I've not seen a similar draw since moving them 30' away.
Carbuff2 (08-18-24), Markfm (08-18-24)
Old 08-18-24, 05:02 PM
  #635
deaded
deaded's Avatar
-edit-
I figured out what ACC meant. Duh.
Old 08-18-24, 05:41 PM
  #636
Carbuff2
Carbuff2's Avatar
Originally Posted by deaded
-edit-
The ACC mode will drain your battery FLAT in an hour, documented.
Thankfully, our dealer emphasized the need to have our 500h Hybrid in READY mode when listening to the radio or setting up defaults.
The following 2 users liked this post by Carbuff2:
deaded (08-19-24), Markfm (08-18-24)
Old 08-18-24, 06:03 PM
  #637
wrinkle
wrinkle's Avatar
Can you share the brand/make and Ampere-hour rating of the 3 batteries, or at least those details of the latest and currently working battery you got ?
Old 08-20-24, 10:32 AM
  #638
deaded
deaded's Avatar
Yep. I'm pretty sure that's what I did. I sat in the car for hours reading the manual and going through the whole system. I (stupidly) thought that the traction/hybrid battery was supplying the power.
CCGS (08-20-24)
Old 08-20-24, 02:32 PM
  #639
pakbet
pakbet's Avatar
My dealer said the same when I experienced this issue a while back. Perhaps it is a setting (or the software version), mine (RX350h) automatically turned off after 10 minutes (It displayed a message that system is being turned off to conserve battery). Or maybe it turned off because the battery was getting low!!
I definitely recall the situation because mine ended up with all sorts of system malfunctions after the car was jump started. I posted this in System malfunction error on dashboard - Page 4 - ClubLexus - Lexus Forum Discussion (post #49). Battery issue is one thing but ending up with all sorts of system malfunctions is a lot more frustrating for me!!
deaded (08-20-24)
Old 08-20-24, 04:26 PM
  #640
Markfm
Markfm's Avatar
My '17 RX 350 non-hybrid also automatically turns off from accessory mode, putting a message up on the infotainment screen before it does so, though IIRC it may be after something like 20 minutes.
(since then we carry a portable radio for drive-in movie watching).
The '17 has zero issues running just the radio, at low volume, for a long time, plenty of battery capacity, no parasitic issues, but it would protect against a case like someone trying to run a high power device off of the accessory socket.
Old 08-20-24, 05:02 PM
  #641
Eagleboy99
Eagleboy99's Avatar
I've left our 350h for three weeks and no issues upon return.
Markfm (08-20-24)
Old 08-20-24, 05:05 PM
  #642
deaded
deaded's Avatar
Yeah. Well, the new RXs apparently require as much power as the Transformers. I think I need to go and find the All-Spark.
Markfm (08-20-24)
Old 08-20-24, 08:55 PM
  #643
wrinkle
wrinkle's Avatar
The sad part is the urban legend that is developing about the underlying reasons behind this problem, which for the most part have no relation to the batteries or EV/HV mode, while being misinformed by the dealers, and NOT being addressed correctly by Lexus. Even the Service Advisor at my 5 K appt, who was responsible and helpful in every other way, did not know that the problem is the charging algorithm, and instead had advised me to run the car more in HV mode.
The following 2 users liked this post by wrinkle:
CCGS (08-21-24), deaded (08-21-24)
Old 08-20-24, 08:59 PM
  #644
WellsB
WellsB's Avatar
Unless someone really pays attention, they'll never realize it's the charging algorithm, and specifically, when the vehicle is being driven, is the issue. If one just checks while the vehicle is sitting in park, they'd never know there is an issue.
CCGS (08-21-24)
Old 08-21-24, 04:04 PM
  #645
deaded
deaded's Avatar
I too would have thought that running it in HV mode would more likely charge it than EV.
Where might I find some information about this charging algorithm?
Quick Reply: Dead 12v battery Incident (merged threads)
