Add third beam?
Add third beam?
I don't have the triple beams but want them. Possible to add the third beam, replace the whole assembly, better third party options? Any ideas possible cost if someone has already done this? Thanks,
wow that much? thanks for letting me know, they're stunning but not worth that, I agree
Several owners (myself included) have raised the 'aim' of the headlights. You can do this without blinding oncoming drivers, while providing more light down the road.
Open the hood, look for the U<--->D hole over each headlamp. 2 full turns UP will get you into the ballpark IIRC.
Verify that the beam cutoff 'drops' while backing away from a wall, on a flat surface.
Carbuff2, thanks for the info. I too have thought that at the stock setting the headlights are aimed too low. The cutoff is significantly lower than the cut off on my '24 Audi A6 (or on my '73 Alfa Spider with Carello H4s, but I digress). I'll make the change and report.
Carbuff2 (04-08-24)
I THINK this is the Topic on headlamp aim...too long for me to look right now.
https://www.clublexus.com/forums/rx-...ust+headlamps+
Carbuff2 (04-10-24)
Freeport49
RX - 4th Gen (2016-2022)
04-21-23 11:16 AM
sushilkuma
RX - 1st Gen (1999-2003)
06-17-22 09:23 AM
Returd
Performance & Maintenance
11-22-18 05:47 PM
