Tire pressure?
Re. RX 2024 RX350 with 21 inch tires. The stated tire pressure is 33 psi. Has anyone tried different psi to see if better ride as long as the changes are safe.
I'm running 38 psi in each tire. Find the ride incredibly quiet comfortable and getting 38 miles per gallon. I've always had it 3-4 extra pounds per tire.
Carbuff2 (05-28-24)
I run 38F, 35R. That tightens up the steering response a bit without diminishing ride comfort.
I admit that I prefer a firmer ride. When test-driving, I thought the RX's handling was too soft & sloppy, but it is acceptable now that I've changed our suspension and steering settings.
Watch out for (dumb) folks at the jiffy type oil places, which we religiously avoid....my wife's company assessed such places (they are horror shows) and one fascinating interaction I had with a manager there (ack) started when I saw him adjusting the air in my tires, which I knew to be just the way I wanted it. When they were done, I pulled out my gauge and noted all the tires were at 44 psi...ouch! So I protested rather vehemently, pointing to the air pressure notification just inside the door which called for 34 psi or whatever it was. But the manager was adamant, pointing to the MAX pressure 44 psi written on the tire....no amount of talking could persuade this person that MAX pressure isn't suggested pressure, but what can you do?
I run 33psi per the door placard. However, the dealer keeps bumping to 35psi (delivery and 5k service). We're moving next week so our selling dealer will not see our vehicle again, but I'm interested to see what the new dealer does at the 10k service (after that, I'll be the service station).
Who else remembers the 'Ford Exploder" situation?
https://en.wikipedia.org/wiki/Firest...re_controversy
I'm one of those guys who reads the sidewall that states, "Do not inflate above XX PSI" and think, "Why does EVERY Joe Blow who works on my car assume that's the recommended tire pressure?! It's clearly the MAXIMUM!" And call me crazy, but I don't exceed the maximum - at least with tire pressure. The speed limit is a different story.
Seriously, doesn't anyone understand the difference between the maximum psi vs the recommended tire pressure for your vehicle?!? Here's an excellent article detailing the difference in case anyone is interested:
https://tiregrades.com/tire-maintena...your-tires-be/
For my 2024 RX350h, the recommended psi is 33 pounds. Because it's summer, I inflate them when they're cold to 34 pounds. They might get up to 35 or 36 while driving. But EVERY TIME I come back from the tire shop or any service, they're inflated to 37 psi or more! ALL of my vehicles have been OVER INFLATED after getting tires or an oil change. Argh!!!
The following 2 users liked this post by Carbuff2:
autotech13 (05-31-24),
gntwarren (06-01-24)
A few extra PSI assures that the pressure won't get too low if the weather turns cool.
Grahaminat (06-01-24)
It also assures that you'll not be running the psi recommended by the vehicle's manufacturer. They did the testing and selected the recommended pressure based on handling, performance, and mileage characteristics. Higher pressures will only firm up your ride and possibly cause poor tire wear too.
I've often thought that as well! That the over inflators just want to sell tires!
jjparker
04-25-08 02:39 PM
