5th gen RX merged rumor and launch threads
#436
#437
I watched a video clip of an Acura engineer must have been a former Acura engineer that stated the reason is it makes the person buying the vehicle think they are buying a superior engine that only requires the best most expensive gas.
#438
Then why doesn’t the current RX require premium? Is it all of the sudden, after 25 years of RX’s, that Lexus needs to arbitrarily up the octane requirement so the vehicle will NOW seem premium?
#439
With some engines ( I believe Mazda has one) Premium is recommended-not required- as it will provide the HP & Torque advertised for that particular engine. If regular gasoline is used, there is no damage caused but the engine also loses some HP. I would think that may be the case with the new engine(s) in the 23 RX.
#440
The 2GR-FKS doesn't require premium because they took an engine designed to run on 91 octane and added a VVT-iW system to lower the compression ratio sufficiently to burn 87 octane without knocking.
More details on this old thread: https://www.clublexus.com/forums/rx-...l#post11164263
#441
#442
There's no marketing value in requiring premium fuel in the Crossover/SUV market, luxury or not.
There's marketing value in offering high-performance engines in the premium sports car market, and those buyers don't care what kind of fuel is needed -- premium is expected..
The following 2 users liked this post by dibl:
dklanecky1 (07-11-22),
jollick (07-11-22)
#443
I completely agree with this. Which brings the discussion back to the beginning, coming full circle: That the premium fuel requirement for the RX is a dealbreaker for many, perhaps me. And that ignoring the requirement and running 87 octane, despite of good data that it will probably do no harm, isn't the answer for those of us who are too cheap to buy premium. There is a reason Lexus requires premium fuel for the 4 cylinder turbo as well as the hybrid engine, both used in the RX. It's not exactly clear what the reason is, but ignoring it isn't the answer. I might live to be 100 even if I never go to a doctor, but skipping all doctoring isn't the answer.
#444
The 2022 RX has curb weight of 4,222 lbs. and is powered by a 295HP engine.
https://www.edmunds.com/lexus/rx-350...eatures-specs/
So, unless they are shaving significant weight off the car for 2023, and if they hope to retain the performance that the RX has today, that 4-banger is going to have to be (a) pretty powerful in the first place, and (b) turbocharged, which is in fact the case, to get anywhere near 295HP. High power to displacement ratios are achieved with premium fuel.
#445
#446
Besides the premium fuel requirement, there are other reasons to look at that turbocharger with a jaundiced eye, IMHO. I would expect the current 10K mile oil change interval to be cut in half, for example, because turbos are famously sensitive to oil quality.
https://www.motorbiscuit.com/2022-to...gine-problems/
https://www.garrettmotion.com/knowle...chargers-fail/
https://repairpal.com/estimator/toyo...placement-cost
coolbrazz (07-11-22)
#447
Now if you keep the vehicle for 3 yrs or so you may not see any problems, but if longer you will and so will the 2nd buyer.
There is a good reason why manufacturers recommends premium as they know that this word is = to lost sales.
The resistance to premium I think is psychological rather than $$$ unless one drives a lot. Just my opinion.
#448
Power ratings of the same engines on Toyota vs Lexus, where they recommend premium fuel in Lexus is typically higher:
2019 Highlander Hybrid - 306hp; same powertrain in RX 450h with premium fuel: 308hp
2022 Tundra 3.5 Twin turbo (Regular Gas): 348-389hp - Lexus LX600 same engine, premium fuel: 409hp.
2023 Highlander 2.4L Turbo; Regular Fuel : 265hp; 2023 Lexus RX 2.4L Turbo - Premium Gas: 275HP
They do squeeze more hp out of the engine by changing the tuning which necessitates the premium fuel.
#449
So here's what it boils down to: Will the 5thGenRX, with the 4CylTurbo91Octane engine cost the same or less, per mile, to fuel as the current 4thGenRx87Octane engine? Is the efficiency of the 4CylTurbo "enough" better to overcome the extra 15% (current here in Pittsburgh) cost of premium (vs regular)? I can't see how.
