Gas Door Not Flush
Old 01-03-24, 10:36 PM
  #106
Received 2,827 Likes on 2,390 Posts
That's one of the most obvious and visible areas of the car it should be properly aligned. Seems like plastic fuel doors are prone to this, assuming that is plastic which I think it is.
I'm sure that can tweaked but I'd be leery of a dealer messing around with my car.
Old 01-04-24, 04:01 AM
  #107
ggebhardt
ggebhardt's Avatar
I am pretty sure the gas door is made of metal. At least mine feels like it is.
Old 01-04-24, 04:54 AM
  #108
Carbuff2
Carbuff2's Avatar
MAGNET TEST! MAGNET TEST! (assuming it is a steel panel, not aluminum)
Old 01-04-24, 06:12 AM
  #109
autotech13
autotech13's Avatar
Originally Posted by bedrock4x
I just purchased a brand new 2024 RX350h in California. The car was assembled in Windsor, Ontario, Canada.
After having it for about a month, I noticed that the gas cap door is misaligned. The left side gap is bigger than the right side gap,
3.1mm vs 1.1mm.
Do you think this can be realigned to correct the gaps evenly to the Lexus Quality Standard?
Damn shame Lexus quality has gone down the tubes in recent years! I hope Lexus reads this forum and begins to make quality cars again!
Old 01-04-24, 06:57 AM
  #110
happy1977
happy1977's Avatar
Has anyone emailed Lexus Corp and shared this link?
Old 01-04-24, 04:52 PM
  #111
happy1977
happy1977's Avatar
Manufacture date May 2023.
Old 01-04-24, 10:02 PM
  #112
Edison_Chen
Edison_Chen's Avatar
Went with my parents to pick up their new 2024 450h+ (Japan built) and the alignment is off too. The bottom right side of the gas lid sticks out a bit more than normal and the spacing is not quite centered. They’ll address it at the first month check-in service.
My 2023 350h looks a lot better than this.
Old 01-04-24, 10:38 PM
  #113
Tried to fix in Photoshop the fuel door seems to be slightly the wrong shape.
Old 01-05-24, 12:24 AM
  #114
Rom
1st Gear
Rom's Avatar
Hello,
I thought the problem only existed on the European market. My RX has exactly the same problem. I find it problematic that the tank cap is made of plastic anyway! For those who like to craft, I have a solution. There is a tab on the inside of the tank cap. This can be easily lifted with a screwdriver and the tank cap can then be pulled out to the rear. You can now see some plastic brackets that have too much play. I cut 5 by 5 mm and 1 mm thick washers and glued them under the plastic holders. It's a bit difficult to explain, but once you have the tank cap in your hand, you'll quickly understand how to proceed. The washers pull the tank cap closer to the holder and so it looks perfect afterwards. Of course, like me, you do this at your own risk :-) .
For me, replacing it is out of the question because you will clearly see the difference in color of the new fuel filler flap afterwards.
Another small note,
I've been buying Toyota since I was 18, with one exception, and later Lexus. I notice that the quality is no longer what it once was. I think that other brands probably aren't any better, but I still think it's a shame because this was always a guarantee at Toyota. Unfortunately, this also applies to the Lexus workshops in my area.
Old 01-05-24, 06:15 AM
  #115
autotech13
autotech13's Avatar
Originally Posted by Rom
Hello,
Another small note,
In regards to your "another small note" That's exactly what I've been saying in previous posts here!
Old 01-05-24, 07:37 AM
  #116
Julius071
Julius071's Avatar
Lets 3d scan and 3d print and reverse engineer these gas door?!
Old 01-05-24, 12:53 PM
  #117
703
703's Avatar
So is Lexus quickly approaching the build quality of Teslas?
Old 01-05-24, 01:51 PM
  #118
budwom
budwom's Avatar
Consumer Reports still rates them as the most reliable brand, for what that's worth. All I know is that both of mine are excellent.
Old 02-13-24, 04:27 AM
  #119
daryll40
daryll40's Avatar
I'm circling back to see what's happened, or not, with the non-flush gas door. Are new 2024 Rx's still hitting dealers with this annoyance? Has there been any sort of fix for those of us with older 5th Generation Rxs with "bulging" gas doors?
Old 02-13-24, 02:37 PM
  #120
Wait4Vtec
Wait4Vtec's Avatar
I mentioned my own QC issues, others just replied deal with it its just a car. That's the direction we head with complacency
autotech13 (02-14-24)
Quick Reply: Gas Door Not Flush
