Did anyone measure the cabin noise level?
#76
If someone was to use the iPhone app to test the 2023RX with either 4 cylinder engine (turbo vs non-turbo hybrid), and use the same app to test the noise in a Gen 4 RX with the V6, the actual accuracy of the app vs a dedicated meter wouldn’t really matter. What we want to know is if the new RX is really noisier than the old RX
The following 2 users liked this post by daryll40:
dklanecky1 (02-19-23),
tedward155 (02-17-23)
#77
If it helps, my Lexus dealership is in Temecula CA and it’s adjacent to the freeway.
When I sat in a model with the pano roof, I could clearly hear the freeway. I had to look to see if all the windows were up. Very surprising.
When I sat in a model with the standard sunroof, the freeway noise was considerably quieter. Much more reasonable.
FMY421 (02-27-23)
#78
I'll check out your thread and contribute. But to quickly update, I took the car out again today and drove for about 40 miles on various interstates around Little Rock. It seems to be tire noise. The difference between concrete road and asphalt is unbelievable. On asphalt interstate the car is as quiet and smooth as advertised. On concrete, it is really loud. The car came with Goodyear. Not sure if it's tire specific or if that's just the way it is on concrete.
tedward155 (02-21-23)
#79
I had a 2021 Toyota Highlander Platinum with Goodyear tires, and they were extremely quiet on newish asphalt but they were the worst ever on cross grooved concrete. Literally made a noise like somebody was blowing in a pop bottle. Fortunately, I rarely had to drive on that section of interstate but if I did, I would’ve been replacing the tires with Michelin. Never in my life did I own tires that sounded so bad on certain types of concrete.
#81
Took the car to the dealer and was given a loaner (21’ RX 350). I can definitely feel the difference in noise level. The 21’ is a bit quieter; it is worth noting it has the standard sunroof not the pano though. My car is still at the dealer and I will keep you all posted.
FMY421 (02-27-23)
FMY421 (03-01-23)
#85
#86
Have you measured the cabin noise level? If not, could you please do at different speeds and share when you get a chance? You can use free apps like Decibel X or an Apple Watch if you have one.
#87
#89
#90
Maybe tread compound might be an impact factor as well, seems likely but don't know how anyone other than a tire manufacturer would know that answer.
So, IMHO, different tires would be a big factor. I don't see why different rim diameters would change the volume, but then again I never switched from one rim diameter to another while keeping the same brand/model of tire. Could use some education there.
autotech13 (12-26-23)
