Auto Start/Stop defeat module...
One of the things I love about this car is that the auto stop doesn't work unless you press the the break harder. I can stop all day long with out the stop/start kicking in. If I want to I press the break a little harder and the engine stops. This is the only stop/start system I could stand and I actually Like to use it occasionally, Long light, drive through.. really well thought out.
The following 3 users liked this post by bdspilot:
I had to look up to make sure I was in the RX350h forum.
ggebhardt (03-21-23)
Turning off auto stop start ?
Do any of you turn off the stop start feature on your 2023/24 RX? This is the first vehicle I've owned with this feature. I have been using it but still not used to it yet. I bought a 2023 gas RX350 and had an older hybrid before so I was used to that vehicle powering down when at a full stop. But, a friend scared me about the auto stop start feature recently that it is bad for your engine. It left me wondering if the engineering of all the newer cars with the stop start feature make it less harmful to the engine long-term.
The following 4 users liked this post by CommodoreAmiga:
Toyota has based many vehicles on this kind of hybrid.
Elvisfan (08-22-23)
I have the non-hybrid RX350 and I turn the auto-stop start OFF every time I get in; it's a habit now. I did the same thing with my Q5 and F-150 EcoBoost - not a fan of abruptly stopping oil flow to the turbo. To each their own, but that's me.
I turn it off also, my braking habits at stops are such that it doesn't come on that much anyway. If I do leave it on, the car tells me to press harder on the pedal at a stop to activate it. So its a cumbersome feature for me.
Change setting of auto stop/start
Is it possible to change the setting of the auto stop/start feature so that it is always off unless I pressed the button to turn it on? Currently, it is always on unless I turn it off.
not until someone comes up with a hack device. The EPA mpg rating is based on auto start/stop so it must be always on when starting the car.
this new 2023 rx is for my mom and I need to make it as easy as possible. (her last was a 2015 - traded @23K 2 mos ago) this fix is hopefully as good as it is on many other brands that the US requires the self-defeat to be single selected.
I'll give my results once its ready/installed.
