2001 RX300 Audio Pin connection 1/3
Old 04-28-06, 01:50 AM
BJ Park
BJ Park's Avatar
Default 2001 RX300 Audio Pin connection 1/3
I hope these informations are usefull.....
Attached Thumbnails 2001 RX300 Audio Pin connection 1/3-rx300_audio_wiring_1.gif
Old 04-28-06, 01:52 AM
BJ Park
BJ Park's Avatar
Default 2001 RX300 Audio Pin connection 2/3
2001 RX300 Audio Pin connection 2/3 (CD Changer Connector)
Attached Thumbnails 2001 RX300 Audio Pin connection 1/3-rx300_audio_wiring_2.gif
Old 04-28-06, 01:53 AM
BJ Park
BJ Park's Avatar
Default 2001 RX300 Audio Pin connection 3/3
2001 RX300 Audio Pin connection 3/3 (Amplifier Connectors)
Attached Thumbnails 2001 RX300 Audio Pin connection 1/3-rx300_audio_wiring_3.gif
Old 04-28-06, 06:05 AM
skippy911
skippy911's Avatar
Thanks a bunch. Do you have the pinouts of the multi display?? How about the radio circuit board itself?
Old 04-28-06, 09:51 AM
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
Is there any mention of intermidiate connectors [cd to radio] harness?
Salim
Old 04-28-06, 06:47 PM
BJ Park
BJ Park's Avatar
Default Connection between CD Changer and headunit..
Salim
There are no signal connection between CD Changer and Radio/tape Assembly.
Only TX (Serial Transmit for control - TX+ / TX-) connections are exist between CD changer and instrument panel.
Except 2 connections (TX+, TX-), all wiring of CD Changer go to Amplifier.
Amplifier gets two sound signals from Headunit and CD Changer. Also there are another TX to Amplifier from Instrument Panel. It control the amplfier with instrument panel so amp can select the sound source.
Thanks.
Old 04-28-06, 07:32 PM
salimshah
salimshah's Avatar
Thanks.
Amp is a module next to the radio and not the sub. right. I assume the volume, balance, fade, bass and treble control are part of the amp ... although from outside they seem to be on the radio/casette unit.
Salim
Old 04-28-06, 07:35 PM
salimshah
salimshah's Avatar
Any one has the insight as to which connector is easy to reach ... one behind the cd or one on the amp .... cd <-> amp.
Salim
Old 04-28-06, 07:37 PM
BJ Park
BJ Park's Avatar
Default Instrument Panel Pinout
Attached Thumbnails 2001 RX300 Audio Pin connection 1/3-rx300_audio_wiring_4.gif
BJ Park
BJ Park's Avatar
Default Multi Display Pinout
Attached Thumbnails 2001 RX300 Audio Pin connection 1/3-rx300_audio_wiring_5.gif
Old 05-05-06, 03:27 PM
Boyson
Boyson's Avatar
Does anyone have pinout for an 1999 model?
There are 2 blue (10 pin, 6 pin) and 1 white (7pin) connector
Thank
Old 06-17-09, 06:38 PM
camarofan
camarofan's Avatar
If i was to go with a stronger amp, should i keep this amp and hook only the speaker wires to a new amp, thereby keeping all the other connections intact????
JR84
06-27-19 09:46 PM
burl
12-27-07 04:58 PM
duane1
07-05-01 02:58 PM
Quick Reply: 2001 RX300 Audio Pin connection 1/3
