Bluetooth Car Kit For 2000 Rx 300 ?
Old 05-30-08, 03:32 PM
gazi001
gazi001's Avatar
Question Bluetooth Car Kit For 2000 Rx 300 ?
Hi,
Anyone ever installed bluetooth car kit-Motorola IHF 1000 or any other devices for 2000 RX 300 ?
Is it possible to integrate with car original stereo? Please let me know if you
have any experiences. Thanks
Old 05-30-08, 09:05 PM
Yatesy
Yatesy's Avatar
Hi,
I've got a Motorola IHF 1000 installed in my 2001 RX (with sat-nav) - It was simple to install - only tricky bits were to find the mute wire that comes from the amp and route the microphone wire up to the rear-view mirror.
When a call comes in the kit mutes the stereo and pauses the CD, the motorola voice tells you the number (or voice tag if it recognises the tel number). You answer the call, hang up and the stereo comes back on.
To make a call you can either dial it on your phone or use the voice recognition on the motorola (either the whole number or saved name).
I'm using the motorola speaker it comes with rather than the car stereo as I didn't want to mess with the wiring plus its easy to hide and loud enough.
Let me know if you have any questions etc.
Cheers
John
Old 05-31-08, 02:24 PM
gazi001
gazi001's Avatar
Hi John,
Thanks for your reply. I have a 2000 RX 300 without navigation. Is it possible to integrate with my original car stereo? I believe the car stereo made by pioneer.
Old 06-02-08, 06:55 AM
thomas1
thomas1's Avatar
Yes I have the same question. Mine is a 99 with the pioneer based system.
Old 06-03-08, 01:05 AM
Yatesy
Yatesy's Avatar
Hi,
All you need to do is find out where the mute cable is on the stereo, thats all you need for it to integrate.
John
Old 06-05-08, 05:20 PM
Kansas
Kansas's Avatar
I can tell you for sure that there is a mute connection in the factory prewire phone harness under the center console on the drivers side in the 95-00 LS400. In the 98-00 the mute pin is the center front terminal of the driver's side phone connector and all one has to do is stick the phone kit's mute wire into the connector and secure it with a wire tie.
I can't tell you if your RX has the same phone connector and mute pin but I can tell you that a dealer installed phone with audio mute was an option up through 2003: http://www.lexus.com/cpo/model_library/RX/2003.html
I am guessing but I would assume that all Lexus models for each model year would have the same factory prewire phone connections -- except for the IS which seems to have never been prewired for a dealer installed Lexus phone.
You can always pick up an audio mute connection on the head unit or amp (depending on model) but it can be easier and less risky to connect the phone kit's mute wire to a prewire phone connector when it is available. One can usually pick up a mute connection where the phone transceiver installs in the back of the car but doing that means running a cable forward to your phone kit -- but that is relatively easy on an RX and info on how to do that on a 99 or 00 has been posted on this forum in the past. But go for an under console connection for the mute -- easier if you can find one.
I should probably modify my signature to say "Resident phone car kit nut"!
Old 06-08-08, 05:28 PM
Yatesy
Yatesy's Avatar
Mr Kansas, you are a car kit legend! It was your diagram that helped me find the correct mute wire.
My mute cable was from the back of the car - you can see the cable on here (its the pink one with heatshink on)
Old 06-09-08, 08:23 AM
thomas1
thomas1's Avatar
Where exactly is that picture located in the car?
Old 06-09-08, 04:16 PM
Yatesy
Yatesy's Avatar
To the right of the spare wheel.
Old 06-09-08, 05:36 PM
thomas1
thomas1's Avatar
thank you, I just couldnt see the perspective, now I will look
Old 03-02-11, 10:48 AM
gazi001
gazi001's Avatar
Hi Yatesy,
I cannot see the pics of mute cable on this post. Why? I tried both google chrome and IE.
Old 03-02-11, 05:00 PM
Kansas
Kansas's Avatar
Here is the 2000 RX300 audio system diagram you requested in your PM. Edit: The telephone mute pin/wire at the amplifier is labeled "TMUT" (telephone mute).
And here is a very old post from "sleepybobcat" who found a mute pin in the back of his RX: https://www.clublexus.com/forums/rx-...led-nokia.html He called the wire color "purple" but I suspect it is "violet" as shown on the 2000 RX300 audio system diagram.
I've recommended looking under the armrest (driver side) on gen 1 RX300's for a phone connector with a mute pin but I don't remember anyone reporting that they looked. I used the mute pin (center front pin in the 6-pin female connector) under the armrest to mute the phone kit in my 2000 LS400 but no one has confirmed if the gen 1 RX300 has the same connector.
File Type: pdf
Old 03-02-11, 05:17 PM
hypervish
hypervish's Avatar
Some of these diagrams of the connectors may be helpful as well: https://www.clublexus.com/forums/rx-...ion-1-3-a.html
Old 03-05-11, 06:22 PM
gazi001
gazi001's Avatar
Why the picture doesnot display? It used to show before.
Old 03-05-11, 07:33 PM
Kansas
Kansas's Avatar
I suspect the picture was stored on a photo sharing website and has since been removed. It's better to upload photos to this forum instead of linking to them on a photo sharing website such as photobucket.
Quick Reply: Bluetooth Car Kit For 2000 Rx 300 ?
