Gear Shift indicator bulb replacement
Old 01-13-09, 01:10 PM
starara
starara's Avatar
Default Gear Shift indicator bulb replacement
Can someone provide instructions for replacing the gear shift indicator bulb (under the gearshift selector) on my 2003 RX300. I have reviewed other threads that discuss this but would like the specifics (or pictures) on how to remove the trim around the gearshift to get to the bulb.
Thanks
Starara
Old 01-13-09, 01:28 PM
blueridge
blueridge's Avatar
https://www.clublexus.com/forums/rx3...ght-out-3.html
Old 01-13-09, 02:10 PM
starara
starara's Avatar
Blueridge
Thanks but I was refering to the indicator lamp next to the gear selector (located at the center of the front console to the right of the driver), not the instrument cluster in front of the driver. Any info on replacing that bulb?
Starara
Old 01-13-09, 03:14 PM
blueridge
blueridge's Avatar
Ahh, sorry, should have read closer. What I posted is the more common problem. I did a search of other posts and can't find anything with pics.
Old 01-13-09, 03:17 PM
mikey00
mikey00's Avatar
Thanks
Starara
You basically just need to remove the trim piece above the shift area to get at the bulb. It is held in by clips and you just start pulling from the top edge. You will need a Sylvania 2721 bulb, available at Autozone. Here is a discussion we had on it back when I did mine. Following the links in the posts will get you pics.
https://www.clublexus.com/forums/rx3...ight=indicator
Old 01-13-09, 04:29 PM
starara
starara's Avatar
mikey00
Thanks for the detail. Any sugestions for a tool to pull the trim with or is it just with the fingers...seems awfully tight. Also I tried the link you gavr for the pictures but I get a message that page can't be found...Can you pls double check and resend.
Regards
Starara
Old 01-13-09, 05:03 PM
mikey00
mikey00's Avatar
Sorry about the bad link. Check here:
https://www.clublexus.com/forums/rx3...umination.html
And here:
https://www.clublexus.com/forums/rx3...r-rx300-2.html
Old 01-14-09, 05:23 PM
starara
starara's Avatar
Mikey00
Fantastic! The second link was what I needed. Thanks all for the assistance.
Regards
Starara
Old 05-21-15, 02:43 PM
bobbrown
bobbrown's Avatar
Default 2007 rx350 shifter bulb replacement
How do you do this on a 2007? Is it the same as a rx 300 ??
Old 04-29-18, 08:15 AM
ReynoldG
ReynoldG's Avatar
08 RX 400h gear shift console light fix, how to get to the bulb ?
Old 04-29-18, 09:53 AM
Gew
Gew's Avatar
Are all gearbox modes supposed to be indicated (illuminated) on the dashboard?
When I use R(everse) it becomes illuminated, but not D, or any other mode.
Well, truthfully, haven't investigated if L N or 2 gives any illumination, but I'm guessing no.
One thing for sure though, P doesn't!
jj0799
03-16-22 11:01 PM
Megapea
ES - 6th Gen (2013-2018)
04-16-19 08:49 AM
mirekti
07-19-16 06:48 PM
CF01
04-23-16 02:38 PM
RX330inFL
01-05-11 07:16 PM
Quick Reply: Gear Shift indicator bulb replacement
