Lexus Rx300 Rear End Clunking Noise
Hello i getting this rear end clunking noise when i am driving slowly over bumps and it seems to be getting worse.. I think it could be the strut mounts but i checked them and they look good so I will be poking around to see if anything is loose.. If anyone can steer me in the right direction I will deeply appreciate it.. Thanks for any help...
Super Moderator
When you say rear end, do you hear it from a certain side of the vehicle.
Does it sound like a clunk or pop on acceleration?
Thanks for that picture it really helps a lot.. Are those the sway bar links that someone mentioned to me? I looked at them but i did not lift the car on jacks so it might be hard to tell.. Should i remove those bolts to see if the rubber is shot on them? Thanks
Super Moderator
The only time I have those adjusted normally is when I do a 4 wheel alignment since mine is AWD.
Dorian7
16
03-17-15 03:30 PM
