Fault codes P0300 0301 0303 0305 0171 0171P
Old 01-18-11, 02:13 AM
thejanitor
thejanitor's Avatar
Default Fault codes P0300 0301 0303 0305 0171 0171P
I apologize in advance as im pretty sure this has been answered before. I just cant find it/make sense of it!!
I had a problem with a hole in my exhaust(the mesh flexible hose part). I ran the car for a few weeks getting 8-9 mpg till i could get it booked in/pay for a repair. Just being a hole in the exhaust i didnt think i would do much damage.
Anyway had the exhaust repaired and it failed the emission test as the cat was flooded with excess fuel. Added a fuel additive/ran it high revs and all good.
50 miles later check engine light and the codes above. I have pulled the negative battery and am waiting for it to show up again and check the codes.
what needs done? Just a sensor? maf? engine misfire doesnt sound good!
any help would be appreciated.
Old 01-18-11, 02:14 PM
Lexmex
Super Moderator
Lexmex's Avatar
I'd take the 3 ignition coils on the rear bank and put them on the front bank and vice-versa and see what codes you get then. The problem in question is related to Have cylinders on the rear bank. Have you gotten a flashing check engine light at any time?
Old 01-18-11, 03:27 PM
thejanitor
thejanitor's Avatar
Yeah every now and again the light flashes. I was hoping this was just a sensor problem too.
What do you think I'm looking at parts and labour? how easy to swap the coils?
Thanks again.
Old 01-19-11, 05:39 AM
thejanitor
thejanitor's Avatar
Lexus saying bank 1 sensor 1 needs replaced and that should sort it. Any idea of denso or lexus part number. And where the sensor is located? Il try swapping ignition coils aswell.
Old 01-19-11, 08:32 AM
Lexmex
Super Moderator
Lexmex's Avatar
Swap the coils first. Usually the flash CEL and those codes you have indicate one or more busted coils.
Bank 1 Sensor 1 (Air/Fuel Sensor) is located behind the engine,
see this thread, https://www.clublexus.com/forums/rx-...el-sensor.html
You will see it in post 5. The Denso part number is 234-9009.
Old 01-19-11, 11:16 AM
thejanitor
thejanitor's Avatar
Thanks again Lexmex. your help is much appreciated.
Cleared the codes via removing battery terminal and after 20 mins or so its showing 2 faults and 1 pending.
0171 1133 and a pending code think it was the 0171 again(cleared before writing it down!)
Old 01-20-11, 11:54 AM
Lexmex
Super Moderator
Lexmex's Avatar
Don't worry about the P0171, that often comes up due to the P1133 issure (which is the same A/F sensor in question behind the engine).
beachlover
02-28-20 09:55 PM
DK Audio
18
11-20-18 07:26 AM
UR2slow88
11-19-10 08:09 PM
jet_jockey
03-07-08 09:53 PM
Gene
11-18-02 10:14 PM
Quick Reply: Fault codes P0300 0301 0303 0305 0171 0171P
