Could the self leveling headlight feature
Old 07-25-06, 07:40 AM
Todd
Todd's Avatar
Default Could the self leveling headlight feature
be contributing to the "curtain" issue with the headlights whereby they do not illuminate well when the raod elevation changes. I know I need to read the manual but would turning off this feature also disable the side to side movement of the lights?
Old 07-25-06, 08:00 AM
dhamaka127
dhamaka127's Avatar
Question side to side movement??
Do the headlights on the 2004 RX 330 with Premium pkg and NAV move from side to side or it is just on the newer ones?
I know my headlights move up and down but i am unsure about the side to side movement. Do I have to be going at minimum speed for them to activate?
Old 07-25-06, 10:04 AM
DakotaRX
DakotaRX's Avatar
If you have the HID lights they are equiped with the "auto-level" which is required per federal mandate for high intensity headlights, that feature can not be turned off. You can adjust the level to some degree. There have been a couple threads on this which you can do a search for. As for the AFS that can be turned off by the switch on the dash and you will get a warning light showing it off. If you have no switch on the dash, then you do not have AFS. The AFS feature works at speeds starting around 20 mph, you can verify that by checking the manual. I'm not real sure if the performance pkg. includes AFS but most likely does.
Old 07-25-06, 12:50 PM
tfischer
tfischer's Avatar
Neither the "premium" package (which is on almost every RX) and even the "Premium Plus" package include the headlights which turn left and right (I forget the name of that trick). From what I know, if you had these, you would have noticed it by now, especially when turning left.
I don't have it, so I'm not sure, but I think the car does have to be moving for this feature to activate.
Old 07-25-06, 02:24 PM
Todd
Todd's Avatar
Default Mine do some sort of a self check
every time you start the vehicle. I can see it in the garage on the front wall.
Old 07-25-06, 02:35 PM
DakotaRX
DakotaRX's Avatar
Like Todd said, everytime you start your vehicle they do a "self test", but that is only if you have your light switch in the "Auto" position. If you have the switch in the off position it doesn't do it. Most of the time I used to have the switch in the "Auto" position so when I turn the RX on the lights do a little test going left and right then centering. It was easy for me to notice this as ours is always in a garage so would see it on the wall. When starting with the switch in the off position it of course doesn't do it.
2005 RX330 Thundercloud AWD, NAV, ML, HID AFS, towing package (with hitch) 18" Thundercloud rims.
Old 07-26-06, 05:09 AM
dhamaka127
dhamaka127's Avatar
Exclamation self check...
I know that mine do a self check but i dont think they do a self check left and right...they only do a self check up and down...
So does that mean i do not have AFS light????...
Old 07-26-06, 05:22 AM
rxdriver
rxdriver's Avatar
In 2004, the AFS system (side-to-side) only came on the Performance Package. You could not add it to Premium, Premium Plus, or Nav/ML.
From 2005 on, I believe AFS became a lot more common.
Old 07-26-06, 08:32 AM
dhamaka127
dhamaka127's Avatar
Thanks for the info...
Old 07-26-06, 09:10 AM
32kcolors
32kcolors's Avatar
Funny, I thought all these "self-checking" were just for the effect, to look cool
Old 07-26-06, 12:50 PM
Frankr66
Frankr66's Avatar
my 06 with NAV/Premium has AFS included
Old 07-26-06, 11:29 PM
Booyah
Booyah's Avatar
My 04 has AFS headlights and I keep my headlight switch to "ON" all the time--so when I go to start the car in the gargage you can see the headlights go up/down and side to side
Old 07-27-06, 03:33 PM
Edison_Chen
Edison_Chen's Avatar
I luv that too, if you leave it on the ON position, and when you start the car; it moves up/down/left/right
Old 11-18-08, 08:21 PM
deepakg
deepakg's Avatar
I have a RX 330 of Year 2004 in which lights go up and down every time I start the car. I do not see any AFS switch. At least I do not know where it is. How do I know if it has the feature of the lights going left /right?
Old 11-19-08, 07:10 AM
The G Man
The G Man's Avatar
If your lights goes up and down when u start the car, it will go left and right on turn, thus, you have the AFS system. Keep in mind, not all model year have the AFS off switch. I am not sure about the 04 RX.
Quick Reply: Could the self leveling headlight feature
