07 RX350 How to remove AC filter behind the glove box
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
Hi everone,
I am new in this forum. I want to replace the AC filter behind the glove box.
In the manual tells that I need to remove two pins (platic)of the hints of the glove box. I look at these pins and do not know how to remove it. What tool do I need and how do I do it?
Thanks
Thanks
This job is simple, don't let the dealer charge you $40.00 for it, buy the cabin filter at auto supply store, around $13.00. Pull those pins out and you can then slide the new filter in, takes two minutes, ENJOY your savings!
It's dark in there, and everything is painted black. Once I got a flashlight on the scene, it became very clear and easy to see how the "pins" work. From there it takes about 90 seconds.
Tell me exactly what I need to do: Twist and pull????
Thanks
you can actually use your fingers. literally, its twist, then pull. there is one on each side. First fine the black screws on either side of the box. you twist htem to one side, and then you can easily remove them.
https://www.clublexus.com/forums/rx-...ir-filter.html
reljam
04-04-07 12:44 PM
