a/c light blinking help
hey guys wassup!! when i was driving my 2004 rx330 today the a/c light was blinking and the a/c was not cooling..can someone help? thanks you
if you drove through a puddle, water may have entered the engine compartment where the belt is. It shuts down the AC as a precaution. usually restarting the car/turning off and on the AC again resets it.
Most likely the magnetic clutch relay failed. Ive done plenty of those on the older RX. Parts are around $70 and labor is $55. If the drive belts get wet the the car will shut down the a/c and you will see the light flash. All lexus cars have that.
Yep, safety of compressor and your pocket book.
Bonus points for who ever finds the reason behind it.
Salim
Salim
The reason behind it is if the drive belts get wet and start to slip, there are sensors on the pully that read this and shut off the compressor. If the belts happen to slip off, the the compressor locks up and the must be towed. Lexus
does this to prevent that from happening. Every Lexus car has this feature.
Also, if this a/c lights flashes when it is dry out then your Magnetic clutch relay is failing. It is a repair that costs under $200.
Jrocxzs
05-27-20 08:40 PM
