Enable the Seat Belt chime?
I have tried the following steps already on a 2004--RX330, but no luck..any other suggestions?
Here is the instruction for reseting seat belt buzzers;
1. Turn the ignition switch to ON position
2. Press the ODO/Trip switch until the odometer display "ODO"
3. Turn the ignition switch off.
4. Turn the ignition switch to the ON position.
5. Press the ODO/Trip switch immediately (within 6 seconds) and hold it down for 10 seconds or more.
6. Continue holding down the ODO/trip switch and fasten the driver side seat belt.
7. Check that the odometer display either "b-on" or "b-off".
8. Press the ODO/Trip switch to change the display to "b-off".
9. Turn ignition switch off.
10. You are done.
10. You are done.
10. You are done.
10. You are done.
10. You are done.
10. You are done.
kbbean08
03-16-19 01:10 PM
