Is it easy to change the amber interior lights?
Old 08-07-11, 04:55 PM
satz
satz's Avatar
Default Is it easy to change the amber interior lights?
Hi all
I don't like the orange/amber courtesy lights in my 07 RX350. Their colour just doesn't look modern.
Has anyone changed the lights to a plain white?
I'm thinking of the bulbs/LEDs in:
-glovebox
-footwell
-door step plate
-interior door handle
Is it a simple matter of replacing these bulbs, or is it more sinister...?
thank you
S
Old 08-07-11, 05:02 PM
Nick318
Nick318's Avatar
They are super easy...use a small flat-headed screw driver and all go well. gl.
Old 08-08-11, 12:33 AM
Benzat17
Benzat17's Avatar
https://www.clublexus.com/forums/rx-...rx-series.html
here you go
Old 08-08-11, 11:06 AM
JoshuaMZX
JoshuaMZX's Avatar
i put the exact same post under the lighting section a couple of weeks ago. The "I Have LED's" post doesn't help as it covers replacing the tungsten bulbs with LED's and not replacing the factory Amber LED's for another colour.
Old 08-08-11, 07:54 PM
HtownBlue
HtownBlue's Avatar
The only difference in the procedure is to find bulbs of the color you would like (soft white, bright white, blue, etc. etc.) and place them in the "sockets" of the old amber bulbs. Lots of sites on the net with tungsten bulbs of different colors.
Old 08-08-11, 09:44 PM
satz
satz's Avatar
thanks guys
If any of you have done the replacements, were there any problems accessing the bulbs (glovebox, footwell and centre console), or finding replacement bulbs?
I'd probably like to replace them with soft white.
Btw...would these be 3w bulbs?
thank you
Satz
Old 08-09-11, 09:31 PM
satz
satz's Avatar
I spent some time looking at the orange / amber bulbs that are used for the glovebox, footwells and centre console. I can't for the life of me work out:
1. how to remove them
2. whether they are a proprietary 'sealed for life' unit
3. whether they are LEDs or bulbs?
Please could some experienced person advise on how to access and replace them?
cheers
Satz
ps. after some further research on the internet, it appears the glovebox and presumably the footwell lights are Type 74 (very slender 1.4 w wedge bulbs)
BUT....I still can't work out how to actually remove them!
Old 08-13-11, 08:00 PM
satz
satz's Avatar
Update: managed to access the orange footwell LED under the driver's side!
After unplugging it from the wiring harness, spent a bit of time dismantling it as far as I could. Used a thin flat blade screwdriver to force the 'inner' part out. (see pic)
Sadly the LED itself seems to be 'incorporated' into the plastic housing, along with a couple of resistors.
Unless there's a way of dismantling it further, I can't see how to change the LED
Attached Thumbnails Is it easy to change the amber interior lights?-dsc00158.jpg   Is it easy to change the amber interior lights?-dsc00159.jpg
Old 08-13-11, 08:13 PM
exmeaguy
exmeaguy's Avatar
Originally Posted by Benzat17
Nope, not the same type of bulb.
Abied
08-05-15 08:08 AM
ncast2523
NX - 1st Gen (2015-2021)
04-19-15 06:32 AM
lilscrapy8
03-12-09 02:58 AM
kidoekid
02-10-09 11:01 PM
mseymour
Lighting
06-01-06 01:22 PM
Quick Reply: Is it easy to change the amber interior lights?
