New Toyota Recall
Old 11-09-11, 05:29 AM
redrocks
redrocks's Avatar
Default New Toyota Recall
Heads up second gen owners:
http://www.huffingtonpost.com/2011/1...n_1083321.html
Old 11-09-11, 05:38 AM
jfelbab
jfelbab's Avatar
Originally Posted by redrocks
Thanks for the heads up.:thumb up:
Another free tank of gas.
Old 11-09-11, 06:39 AM
RX330inFL
RX330inFL's Avatar
Just saw that:
http://www.msnbc.msn.com/id/45218616.../#.TrqQNM2gVuY
"The latest recall is due to the possibility that the outer ring of the engine's crankshaft pulley may become misaligned with the inner ring, causing noise or a warning signal to light up, the company's U.S. sales unit said in a press release. If the problem isn't corrected, the belt for the power steering pump may become detached from the pulley, making it suddenly more difficult to turn the steering wheel.
In the United States, the automaker is recalling 283,200 Toyota brand cars, including the 2004 and 2005 Camry, Highlander, Sienna and Solara, the 2004 Avalon and the 2006 Highlander HV. Its recall of 137,000 Lexus vehicles includes the 2004 and 2005 ES330 and RX330 and 2006 RX400h."
Old 11-09-11, 07:38 AM
soda7o
soda7o's Avatar
good to know
how do you know if your car is affected?
Old 11-09-11, 08:15 AM
RX330inFL
RX330inFL's Avatar
Originally Posted by soda7o
good to know
You will eventually receive a letter in the mail. However, prior to that you may see a posting on the Lexus Drivers - My Lexus site if you log in. Will be under Safety Recalls:
https://secure.drivers.lexus.com/lex...-lexus/home.do
Old 11-09-11, 08:17 AM
jfelbab
jfelbab's Avatar
good to know
They have sent notifications via USPS mail in the past. It sounds as if the dealers will need to have some part(s) on hand for the remedy so I doubt this will get done this year. More info will be forthcoming from Lexus/Toyota.
Be sure to bring your Lexus in with a nearly empty gas tank as most dealers will fill it as part of the recall program.
Old 11-09-11, 08:28 AM
Carver
Carver's Avatar
Many did not get letters on the carpet clips but it always show up at the Lexus site in your driver section.
Old 11-09-11, 08:35 AM
RX330inFL
RX330inFL's Avatar
Official press release...
File Type: pdf
Old 11-09-11, 09:03 AM
jamodeo
jamodeo's Avatar
This might just be impeccable timing or just a weird coincidence but I have noticed sometimes while turning (it has only happened a few times) that doesn't feel like the wheel wants to move and I just have to turn hard and hit the gas a little and then its fine. Also my engine has been making some squeaking noises lately that I thought was just my serpentine belt needing replacement. Does this recall mention anywhere that the steering will become difficult 100% of the time after it fails or just once in a while like on mine? If anyone has any insight i would appreciate it.
Thanks,
-Joe
Old 11-09-11, 09:38 AM
mandyfig
mandyfig's Avatar
I just read a portion of the Toyota announcement and yes the failure mode is: hard to steer.
Old 11-09-11, 11:26 AM
lexus114
lexus114's Avatar
when are these friggin recalls going to end?
Zodiac
Zodiac's Avatar
I hope Lexus will fill gas up with recall also.
Old 11-09-11, 12:15 PM
RX330inFL
RX330inFL's Avatar
Quoth the raven, “Nevermore.”
Old 11-09-11, 12:39 PM
infinirx
infinirx's Avatar
Thanks allot. Going to check on this ASAP.
Old 11-09-11, 12:53 PM
RX330inFL
RX330inFL's Avatar
Perhaps Toyota/Lexus is trying to tell me something.
<sarcasm> My headlights are not as bright as they should be due to the moisture that is constantly present inside the lenses. So, with my nighttime vision impaired when I am driving those back roads I need to be all the more careful because if something were to require me to use my brakes in an emergency I would not be sure if I hit the brakes whether or not the floor mat or other carpet piece would be in the way of the brake pedal. Or, perhaps if those were clear the brakes would fail due to the brake booster problem. And, let us just forget about trying to swerve out of the way as there is a good chance the power steering may not be up to the job either. </sarcasm>
:sigh:
Quick Reply: New Toyota Recall
